  • 5 months later...
  • Replies 252
  • Created
  • Last Reply
Top Posters In This Topic
Its been a while since I updated this, so I thought I'd give a quick update!
I've took the glanza off the road for the coming months to have some work done which includes a bush overhaul, poly bush droplink bushes, ball joints, track rods and ends, new cv joints, N/S/R caliper, arches sorted (small rust bubbles), larger bore slave cylinder and a new clutch!
The clutch i went for in the end was the ORC309D which I ordered from RHD Japan.
So, I managed to get myself a daily which will enable me to do the work with no interruptions! Photos will follow but it's a 2008 vw polo, 47k! 330miles to a tank of fuel! Perfect!
Edited by Sefton-EP91
  • 2 weeks later...
Genuinely can't wait to get the clutch in! I just want to drive it again! lol I'll starting the gearbox removal in the coming days! So it will soon begin!
Thanks for the kind words guys I appreciate all the comments!
  • 3 weeks later...
Update, I've been waiting to find abit of time to get round to fitting my ORC309d clutch and managed to get it done this weekend just gone! Had couple of issues but I'll get to those, first of all a quick photo of it all bolted up!
I originally had a spec 6 puk sprung clutch on the car but was having some major issue with engaging gears and I think I found why! After 10,000miles this has happened!
The springs have shot out of the centre on this picture!
Clutch cover has been catching the inside of the gearbox!
So anyway to cut a long story short she's now drivable again and my god what a difference the ORC makes! Whilst I was there i changed the gear oil and changed the oil and filter for a HKS oil filter and Fuchs oil.
I took the car out for its first test drive after fitting and come onto boost a small amount and to my surprise a massive bang! Limped the car home and found the oil filter had shot of the housing! The threads on both the filter and housing were fine and seal was fine! Turns out the thread pattern was incorrect but was just able to tighten it without any problems! Moral of the story is, don't buy hks filters from Euro car parts! Even if you are told they fit! Could have been majorly expensive!
So new Toyota filter and Fuchs oil she is driving again!
  • 3 weeks later...
So a small update, rear calipers are being removed at some point this week to be sent away, there going to be refurbished, seems to be the only option at the moment as one caliper is £215 and for both to be refurbished it's just over half that!
I've also got something special as I was getting bored of constantly buying maintenance parts for her!
Zisco 6 point rear strut brace!
  • 1 month later...
Took a small trip to fensport performance today to get my gauges all plumbed in and wired up!
Almost done!
Complete!
Fensport stage 5 500hp sprint car!!
There quality of work is second to none, really nice guys as well, was my first time going to fensport and can honestly say had a great first experience! Would highly recommend them to anyone!
They are really decent guys aren't they. Had my old gt4 mapped by Adrian. Had a good old nose around while I was there and there's hidden gems all over the place like a turbod Yaris, ISF and at the time the Corolla Gt4 and the Celica sprint X
  • 2 weeks later...
Small update, today was MOT day and she passed again, some advisories but is to be expected on a car almost 20years old!
Rear brakes are knackered - calipers are sent away for refurb and new discs, pads and bearings are awaiting fitment
Driver side outer cv boot is split - have a driveshaft awaiting to go on with good boots on
Front tyres are below 2mm - x4 nangkang ns-2's ordered
I've also got the following ready to go on,
Ultra racing Front strut brace
Polybush front wishbones
Polybush drop links
TRD engine mounts
new AEM wideband sensor - old one faulty
I'm hoping to have the above all fitted and ready for when japfest comes around!
OSF outer cv boot split - have a driveshaft awaiting to go on with good boots on
Front tyres are below 2mm - will be ordering new ones in time for my track session at japfest
Polybush drop links
TRD engine mounts
Generally jumping all over the place, it will do its calibration at the start then read full lean on idle, it reads around 14.0 with ignition off. I've tried a new sensor and it worked perfectly!
Edited by jiggaman_16
Also whipped together a quick spec list..
Engine spec:
PEC Forged 74.5mm Piston Kit With Rings And Pins
PEC 4EFTE Forged Con-Rod Kit With ARP Rod Bolts
Athena 1.2mm Uprated Metal Head gasket
ARP 2000 Uprated Headbolt Kit Inc New Washers
New Genuine Toyota Full Gasket Kit
New Genuine Toyota Oil Pump
OEM Water Pump With New Pulley
OEM Cambelt Kit With New Tensioners And Rollers
ACL Main Bearings Kit
ACL Big End Bearing Kit
ACL Thrust Washer Kit
Fully Machined And Polished 4EFTE Bottom End
Fully Cleaned and Rebuilt 4EFTE Cylinder Head Built To Standard Spec
Block, Head and Rocker Cover Cleaned
An-8 Race Spec Rocker Cover
New NGK Iridium Spark Plugs
New Blue Magnecore 8mm HT leads
Air Cooling/intake:
WEPR Half Size Radiator with AN6 Overflow
WEPR rear entry intercooler kit
Standard intake manifold (Thoroughly cleaned)
Apexi power intake air filter (Relocated behind grille)
Misc/Exhaust/Fuelling:
Japspeed full exhaust system
WEPR Ram-horn external wastegate manifold
WEPR decat pipe
WEPR screamer pipe
Tial MVS V-band wastegate
Td300 billet td04 hybrid turbo
HKS SSQV dump valve
Walbro 255lph fuel pump
TD 430cc Injectors
Standard fuel rail
SARD Fuel Pressure Regulator
Braided fuel lines
Roose Motorsport ancillary hoses
Blue vacuum hoses
Electronic's
EMB mapped by TD (1.4bar producing 300.9bhp)
ZISCO field harness
GFB G-force 2 Boost controller setup by TD
Apexi turbo timer
AEM Wideband gauge
Oil filter adaptor plate
Swoosh oil pressure gauge
Swoosh oil temp gauge
Smoked boost gauge
Suspension/Brakes
WMS 4pot Calipers
277mm front discs
Ferodo DS2500 front pads
Earls braided brake lines
20mm hubcentric spacers (front)
20mm hubcentric spacers (rear)
Standard rear brake setup
Lowered on lowering springs
KYB shock absorbers
Exterior
16" Rota Track R alloy wheels
Continental tyres front
Avon tyres rear
Optional duck tail spoiler (rep)
Uncut 98 spec front bumper
Laguna splitter
Optional wind deflectors
Crystal fog lights
Interior
Unknown brand short shifter
Toms gear knob
Optional 5 piece starlet mats
New gear gator
3" shifter extender
Clarion DVD heat unit
Alpine speakers (front)
Pioneer Carrozzeria speakers (rear)
Sparco drivers bucket seat on custom rail
98 spec interior
3 pod a pillar trim
Indiglo dials
Getting longer by the week
Question. Does PEC manufacture the forged parts u mention or do they just sell & distribute forged parts?
PEC manufacture them mate, I got all the forged items through ID-WORKZ :)
