smb2011 Posted June 10, 2013 Posted June 10, 2013 What is the easiest way to tell with out taking the head and everythink off? Im running td04 at 253bhp mapped to 1bar which i think is quite high for 1bar on a stock engine i have seen them around 220-240 Quote
iamlegend Posted June 10, 2013 Posted June 10, 2013 really who mapped this? got a dyno print out? wip the sump off... Quote
jayc-glanza17 Posted June 10, 2013 Posted June 10, 2013 take sump off and take some pictures, it soon tell if its forged or not..253 at a bar on a td04 is a great result, but who tuned it? Quote
smb2011 Posted June 10, 2013 Author Posted June 10, 2013 Td done it i have two print outs from them at 245bhp with the turbo running in (new turbo) and one from a month ago with a oil change vpower and turbo run in at 252 down in reading dyno il whip the sump off what am i lookinh for any type of name/numbers Quote
akyakapotter Posted June 10, 2013 Posted June 10, 2013 you say new turbo is it a td hybrid ? id use a bore scope up the oil return to see whats inside sod taking the sump off bastard to reseal Quote
TurboTobz Posted June 10, 2013 Posted June 10, 2013 You'll see I there forged they look totally different to oem take a pic if you get stuck Quote
smb2011 Posted June 10, 2013 Author Posted June 10, 2013 Its just a re-condistion turbo that needed running in, il take the sump off and that a picture but i wouldnt of thought no one would have mentioned it wasnt forged but it just seems really high bhp for 1bar i dont know what esle that could have been done to be at 252bhp Quote
AdamB Posted June 11, 2013 Posted June 11, 2013 Chuck a bore scope down it, as above the sump can be a pain in the neck to seal again. Quote
ryan lang Posted June 11, 2013 Posted June 11, 2013 use a bore scope bud if you can get a garage to have a nose. if you can get a pic from their monitor if its clear enough Quote
Chris_14a Posted June 11, 2013 Posted June 11, 2013 If your car is a 98 spec they had different cams and usually make more. At a bar it wouldnt matter if it was forged Quote
ryan lang Posted June 11, 2013 Posted June 11, 2013 If your car is a 98 spec they had different cams and usually make more. At a bar it wouldnt matter if it was forged whats different about them :s Quote
daniel_g Posted June 11, 2013 Posted June 11, 2013 ^^ 98 spec had different cams ?? Quality, i put a 98 spec engine in my GT, poaaaawwwweerr. Quote
akyakapotter Posted June 11, 2013 Posted June 11, 2013 Yeah the cams are different that's why they make a little more power than the 96spec Quote
akyakapotter Posted June 11, 2013 Posted June 11, 2013 (edited) i dont think they are differentThey are mate mike at td looked into it when 98spec engines made more power that 96spec ones Edited June 11, 2013 by akyakapotter Quote
akyakapotter Posted June 11, 2013 Posted June 11, 2013 whats different? specs? pics?He was telling me part numbers are different cams on the 98spec are a little bigger apparently Quote
ryan lang Posted June 11, 2013 Posted June 11, 2013 i dont think they are bud. 99.9% sure they are the same. they have any pics and measurements to show the difference? Quote
Weyro Posted June 11, 2013 Posted June 11, 2013 we all know that 96 specs are for real men, and the 98's are for their wives and daughters ;) Quote
akyakapotter Posted June 11, 2013 Posted June 11, 2013 (edited) 2 different types for 98spec ryan Edited June 11, 2013 by akyakapotter Quote
daniel_g Posted June 11, 2013 Posted June 11, 2013 Interesting stuff there ^^ Also, Weyro, GTs for real men hahahaha. Quote
ryan lang Posted June 11, 2013 Posted June 11, 2013 i know the part numbers are different. but doesnt mean they are different in spec whats the lift and duration for both? Quote
akyakapotter Posted June 11, 2013 Posted June 11, 2013 different according to mike that's why the late spec Glanza's are making better power than the older ones Quote
ryan lang Posted June 11, 2013 Posted June 11, 2013 could be because they are newer? holding compression less and have 2 years less of a bollocking on them. ask them to post the difference with pics please dude. i could be wrong, but id like to see the difference if i am Quote
