Any ideas as why it would be doing that? It's not leaving oil on the floor and its not chucking it out my turbo? So need some possible theory's lol cheers guys
Valve stem seals, is it putting out blue smoke atal? If not it could be heading into the water system? If its using it, it must be going some where.
If it's not chucking any smoke out it must be a leak.
I would bet its a crank seal as they are sealed at both ends really, although if it was gearbox end your clutch would be slipping. Try pulling the bottom timing cover off and check in there if nothing else is visible from the top end :)
chucking it out your turbo? turbo oil seals? does it chuck smoke out on boost? check oil for water contamination? like others have said leaky seals
Edited by Broony
Yeah I do have a catch can but only a trickle of oil in it really :/ but I've got no leaks that I can see so either new engine is soon to go bang or its a super duper mystery lol
