Ep'd Posted July 10, 2013 Posted July 10, 2013 Why buy an aftermarket front strut brace when the black oem one does the job? A bit confused as to this. Quote
daniel_g Posted July 10, 2013 Posted July 10, 2013 For looks and added JDM points and shit. Think the OEM one is sound tbh. Quote
Addymk2 Posted July 10, 2013 Posted July 10, 2013 Always confused me too. Especially considering those floppy ended things aren't nearly as stiff. I think it's just down to JDM bling. Quote
WallaceGlanza Posted July 10, 2013 Posted July 10, 2013 (edited) Always confused me too. Especially considering those floppy ended things aren't nearly as stiff. I think it's just down to JDM bling. Pretty much all aftermarket ones will be much stiffer than the stock one, it has a very thin wall tube with pathetic thin welds onto the end plates, the adjustable plates on the likes of a cusco are solid once bolted down. Grab the stock one and give it a good shake - it will flex easily, a cusco or similar won't. Edited July 10, 2013 by WallaceGlanza Quote
Ep'd Posted July 11, 2013 Author Posted July 11, 2013 Pretty much all aftermarket ones will be much stiffer than the stock one, it has a very thin wall tube with pathetic thin welds onto the end plates, the adjustable plates on the likes of a cusco are solid once bolted down. Grab the stock one and give it a good shake - it will flex easily, a cusco or similar won't.But it does the job? Toyota put millions into design so it must be good?Like the rear 3 point brace which is amazing!Might get the oem one chrome plated Quote
rob_bower Posted July 11, 2013 Posted July 11, 2013 Under normal load it will be fine but if your seriously abusing it sighing stiffer would be better. But there are plenty of other things I'd buy first. Quote
Addymk2 Posted July 11, 2013 Posted July 11, 2013 Theres a test on youtube somewhere with the cusco ones. I think UltraRacing did it. Might be stiff in your hand but that's about it. On a proper Jig which replicated extreme loads on the suspension turrets theyre like elastic bands. Quote
Fozzie Posted July 11, 2013 Posted July 11, 2013 May as well just weld some box section between the turrets, that'd do the job Quote
Glanza Mac Posted July 11, 2013 Posted July 11, 2013 Cusco Carbon fibre strut brace... JDM, Lighter and still strong Rob. Quote
WallaceGlanza Posted July 11, 2013 Posted July 11, 2013 Theres a test on youtube somewhere with the cusco ones. I think UltraRacing did it. Might be stiff in your hand but that's about it. On a proper Jig which replicated extreme loads on the suspension turrets theyre like elastic bands. The standard one would probably snap on that jig then! Quote
Addymk2 Posted July 12, 2013 Posted July 12, 2013 The standard one would probably snap on that jig then! The Cusco one might aswell lol at least that way it showed it tried Quote
