Basically my front break on the passenger side started squealing and squeaking so we took the calliper off lubed up the pistons and tool out the old pads to find the pad on the inside of the calliper was bent the pad was coming off of the metal backing so changed the pads and have driven it about 3-4 days and the same thing has happend the previous pads were fitted by my local garage and these by myself yet the same thing has happend again on the same pad made sure everything was as it should be Aswel don't see why it's happening or what's causing it
Any help appreciated
Thanks
Sam
WHat condition is the disc in? As your ment to do discs and pads at the same time really!
If the pad was that nakered... I can only imagine the disc would be fooked as well!
The disk seemed to be ok didn't appear to be warped or have any cracks in it or anything but I'm no mechanic so you think it could be the disks
You got a siezed or sticky caliper ? Pads not jammed in or that ?
You can do pads without discs, but if doing discs youre ment to change pads too.
Well I serviced the callipers when I changed the pads greased up the pistons and they were all making freely and everything went back as it should and its bent and destroyed a new pad in a matter of days
Sounds like the disc is warped all your calumets are tight aren't they. Haven't worked loose or anything
Sounds like the disc is warped all your calipers are tight aren't they. Haven't worked loose or anything
Definitely all tight checked the whole lot over twice on each side if it was a warped disk wouldn't it affect pads on both sides of the disk not just the one side ?
Yea mate the padd slides freely in the carrier everything would appear as it should be I just serviced the callipers aswel all greased up everything's sliding well
Thanks for input everyone but I'm convinced its not the calliper gonna try putting disks on the front new pads see how it goes
This is a really odd one!! A pad breaking off it's backing would suggest massive overheating (ie caliper sticking on - due to sticky sliders, sticky pistons or sticking-pads). But you say it's ok?
By the way you should make sure you never get normal mineral oil or grease on brake rubber seals as it can perish them, lubricate the pistons with brake fluid when you put them in the caliper....
MASSIVE wheel bearing failure might do this too in theory, but the wheel would be all over the place so you'd notice. Or crash.
Stripped caliper bolt - tightening slightly then slipping "loose" again?
Or the lining inside the flexi pipe is starting to fail causing the fluid to flow into calliper but not return. Had that happen on mines.
The pads not totally breaking off the backing its bending the backing away from the pad on the top part of the pad on the inside of the disk
All the sliders and pistons are lubricated and would seem to be moving freely
Just don't want to she'll out for disks when it could well be the calliper itself ?
As to checking the lining in the flexi pipe how would I do this
Thanks
