Rebuilt 5efhe
brank new 4efte pistons
3ete crank
5efhe rods
New bearings
New seals / Gaskets throughout
5efhe head and cams, intake, all acid dipped/cleaned etc
New water pump and thermostat
Custom Exhaust manifold ($850)
td04 turbo
racepro 32mm wastegate, with downpipe which plums back into exhaust if wanted
link ecu
vr4 injectors
MSD blaster 2 coil
TRD leads
Front mount intercooler
stainless piping
pod filter
4 puk excedy clutch
Toyota LSD gearbox.
Custom axels, with new CV's
Lowered on king springs
Whiteline rear sway bar
Bosch in tank fuel pump
Made 173hp on 12psi on a very conservative tune. Car is from New Zealand, I believe its been for sale for a while now.
