Adeeb1395 Posted August 13, 2013 Posted August 13, 2013 Is it possible to convert my ep 82 to ep85 ?What are the things do i need?Drive shaftGearboxRear diff and? Quote
mikey4410 Posted August 13, 2013 Posted August 13, 2013 not something thats really in ure interests to do due to the huge amount of work involved,im sure this question has been asked before on tgtt and similar was said. alot easyier to get an ep85 all the best in whatever u decide Quote
TurboTobz Posted August 13, 2013 Posted August 13, 2013 Tunnelling for prop would be a lot of work I should think, you need an 85 basically Quote
Jhandy Posted August 13, 2013 Posted August 13, 2013 apprently the rear engine mount is completly different and everything, for the money you would spend converting one, you may aswell search the web and try and find one in japland and import it Quote
turbo Grant Posted August 13, 2013 Posted August 13, 2013 And the rear floor pan is totally diffent for axel mounts. You would need to make a whole new floor pan. Better off importing one for a couple of grand. Quote
daniel_g Posted August 13, 2013 Posted August 13, 2013 (edited) Ive just got an 85 and the floorplan is waaaaay different, the rear mount is different aswell obviously, rear beam area too, rear suspension.First problem would be trying to find 85 running gear. Edited August 13, 2013 by daniel_g Quote
Adeeb1395 Posted August 31, 2013 Author Posted August 31, 2013 My country doesn't allow to import cars which's model is before 2007.the rule is, i can import (max) 5 year earlier model car from the running year......thats the main prob! Any other idea? For importing or convertion? Quote
