PWG123 Posted August 28, 2013 Share Posted August 28, 2013 I Brought a zisco manifold from ebay (yeah shouldn't off), and it keeps blowing manifold gaskets it's been through two now it's fine when it starts as soon as boost is hit, ticks from manifold and the bolts can be Done up tighter. would there be anything causing the problem in the head like the bolts not nipping up? or maybe the manifold needs skimming. Thanks Quote Link to post Share on other sites
yaristurbo Posted August 28, 2013 Share Posted August 28, 2013 skiming the head hasnt cracked as it?maybe try locking washers too Quote Link to post Share on other sites
Idrees Posted August 28, 2013 Share Posted August 28, 2013 I would check both flanges on the manifold are straight and get them skimmed if required, when reassembling I would use some Loctite thread lock too. Quote Link to post Share on other sites
PWG123 Posted August 28, 2013 Author Share Posted August 28, 2013 skiming the head hasnt cracked as it?maybe try locking washers toohead hasn't been skimmed, I meant getting manifold skimmed. Quote Link to post Share on other sites
PWG123 Posted August 28, 2013 Author Share Posted August 28, 2013 I would check both flanges on the manifold are straight and get them skimmed if required, when reassembling I would use some Loctite thread lock too.that is next on the agenda, to get skimmed.We put loctite and they still moved when manifold got hot. Quote Link to post Share on other sites
Glanza-Ben Posted August 28, 2013 Share Posted August 28, 2013 Are you using genuine gaskets as the eBay ones are shite and blow all the time Quote Link to post Share on other sites
MARC MOSS Posted August 28, 2013 Share Posted August 28, 2013 Completely agree, eBay gaskets suck dog shite and disco manifolds don't blow Quote Link to post Share on other sites
PWG123 Posted August 28, 2013 Author Share Posted August 28, 2013 Where do I get decent gaskets? and the first that blew I made myself, so probably extremely unlucky with the gaskets. chess Quote Link to post Share on other sites
Gainzy Posted August 28, 2013 Share Posted August 28, 2013 Always go for genuine toyota gaskets anything else is usually shite! Quote Link to post Share on other sites
Azz Posted August 28, 2013 Share Posted August 28, 2013 Just put a ruler on edge across the manifold flange to see if its straight or not Quote Link to post Share on other sites
akyakapotter Posted August 28, 2013 Share Posted August 28, 2013 ID-Workz can sort you out with head to mani gasket fire him a pm Quote Link to post Share on other sites
PWG123 Posted August 28, 2013 Author Share Posted August 28, 2013 ID-Workz can sort you out with head to mani gasket fire him a pm ok Cheers will do . Just put a ruler on edge across the manifold flange to see if its straight or notguna do this tomorrow cheers. Quote Link to post Share on other sites
Glanza-Ben Posted August 29, 2013 Share Posted August 29, 2013 Where do I get decent gaskets? and the first that blew I made myself, so probably extremely unlucky with the gaskets. chessThat's why your having trouble the manifold will be fine being zisco the gasket is at fault, id workz supply genuine metal gaskets that won't blow every time you hit boost Quote Link to post Share on other sites
Jamz Posted September 1, 2013 Share Posted September 1, 2013 My mate had the same problem, changed the gasket to a decent one and has been fine since. They fray apart are cause a ticking sound his was mani to turbo i believe. Quote Link to post Share on other sites
PWG123 Posted September 1, 2013 Author Share Posted September 1, 2013 My mate had the same problem, changed the gasket to a decent one and has been fine since. They fray apart are cause a ticking sound his was mani to turbo i believe.Yeah this is exactly it mate, nail on the head. It's fine on idle as soon as boost is hit, starts ticking. Quote Link to post Share on other sites
PWG123 Posted September 1, 2013 Author Share Posted September 1, 2013 Now ordering metal Gaskets so hopefully that will sort it. If not skimming :/. Quote Link to post Share on other sites
Matt1878 Posted September 1, 2013 Share Posted September 1, 2013 Now ordering metal Gaskets so hopefully that will sort it. If not skimming :/.As long as you order genuine Toyota gaskets you will be fine mate Quote Link to post Share on other sites
PWG123 Posted September 2, 2013 Author Share Posted September 2, 2013 As long as you order genuine Toyota gaskets you will be fine mateordered from idworks. so hopefully be here tomorrow. Quote Link to post Share on other sites
