Dan_Henderson Posted September 8, 2013 Posted September 8, 2013 Ok lads so if u had a completely standard 4e-fte starlet what sort of cash would we e talking to get t running 300bhp? Quote
james101090 Posted September 8, 2013 Posted September 8, 2013 Are we talking appropriate other mods too I.e diff and brakes? Will be more 7-8 only in my opinion though. Depending where parts are sourced, quality of parts and what work you do yourself. Quote
AdamB Posted September 8, 2013 Posted September 8, 2013 If you buy second hand you can get there at a massive reduced cost Forged engine - £1500-£1800TD turbo kit - £600-1200Management system - £800 ish Then obviously your going to need 460cc + injectors, exhaust system, fpr. Plus LSD, brakes, suspension mods. Quote
Dan_Henderson Posted September 8, 2013 Author Posted September 8, 2013 What is needed to forge engine other then pistons and rods? Quote
ro55ifumi Posted September 8, 2013 Posted September 8, 2013 If you buy second hand you can get there at a massive reduced cost Forged engine - £1500-£1800 TD turbo kit - £600-1200 Management system - £800 ish Then obviously your going to need 460cc + injectors, exhaust system, fpr. Plus LSD, brakes, suspension mods. Clutch,Rolling Road Time etc John Quote
shorty Posted September 8, 2013 Posted September 8, 2013 Lmao if it where cheap all cars on this site would be massive power. Quote
AdamB Posted September 8, 2013 Posted September 8, 2013 (edited) It's not cheap by no means, however it doesn't have to be expensive if you build it yourself and look out for bargains. There's plenty of help available here and around the net As to answer the question what you need is : Forged pistonsForged connecting rodsStock crankHeadgasketHeadboltsCrank boltsMain bearing shellsRod bearing shellsThrust bearingsOil pumpWater pumpEngine rebuild gasket kit As you go through there will be things you'll find that need replacing like hydraulic lifters, valve guides, valve stem seals, valves etc. You have to check everything is within tolerence. Edited September 8, 2013 by AdamB Quote
shorty Posted September 8, 2013 Posted September 8, 2013 If your looking at a 300hp power build do not use oem spec headbolts. Use arp. Quote
DevonGT Posted September 8, 2013 Posted September 8, 2013 If you buy second hand you can get there at a massive reduced cost Forged engine - £1500-£1800 TD turbo kit - £600-1200 Management system - £800 ish Then obviously your going to need 460cc + injectors, exhaust system, fpr. Plus LSD, brakes, suspension mods. Clutch,Rolling Road Time etc John Mapping. Quote
daniel_g Posted September 8, 2013 Posted September 8, 2013 I'm with Adam on this, it could be done at a decent price if you do all the work yourself and find bargain used parts. Although, i priced up everything needed to build a forged engine myself, and with the lot + machine work it came to more than what TD & Race-Tech charge. Quote
