75w-90 but theres lots and lots of different brands. Ive even seen some reccomend using automatic atf oil. Google it as the opie oils guy has talked about oil types loads
  • 5 months later...
  • 3 years later...
yeah...i've done it a few times now...if i had to try to take a guess, i'd say 1.8 - 1.9 liters to be closer
if you put in 2 liters with the car jacked up at the front, when you lower the jack and level the car, a small amount would flow out the "level hole"
