Then it most likely is adjustable, you will probably have to experiment when the length until you have the boost you want
The longer the actuator arm the less boost,
you will probably need to lengthen your to get it 0.5
Glanza or gt? I ran 0.8 td04 on standard eu standard fpr fuelled fine if not slightly rich
Yeah I've been running a TD04 at 0.8Bar of boost, standard ecu, standard injectors, standard fpr.
It runs a bit rich at the top of the rev range ( 10.8 ) which hopefully is alright. I'm no expert by any means.
Edited by Patches
