Sandham Posted September 24, 2013 Posted September 24, 2013 Hi fitted my td04 kit yesterday i got from glanza sheeny, all seems well except the turbo sounds really whistley when building boost?Ive meshed the turbo because i didnt have the correct size relocation pipework.. Could it just be because of this? Quote
Socks Posted September 24, 2013 Posted September 24, 2013 Mesh will make the turbo ALOT louder... Ontop of that it is much bigger then a ct9 too! Get a video uploaded to youtube and link us up! Quote
StuDoc 72 Posted September 24, 2013 Posted September 24, 2013 Are the blades chipped? If the blades are damaged it causes a turbo to whistle its tits off. Quote
Sandham Posted September 24, 2013 Author Posted September 24, 2013 Will do, and the turbo seemed ok to me but to be honest i dont have much knowledge when it comes to the ins and outs of one other than basics like shaft play Quote
StuDoc 72 Posted September 24, 2013 Posted September 24, 2013 If you have a look at the blades on the comp wheel and see any chips on it then its likely this is causing it but as said above. Having no filter causes the noise to be more obvious. Quote
Sandham Posted September 24, 2013 Author Posted September 24, 2013 (edited) Now its all fitted i cant really see into the housing but ill try have a look later when i change the oil and filter. Tried to video it but doesnt really pick the noise up too much. It builds and holds boost all the way through the gears and once it reaches full boost (0.5 bar) the whistling quietens offThere seems to be some play in the shaft but doesnt seem to be alot, the ct9 i removed had more. Edited September 24, 2013 by Sandham Quote
StuDoc 72 Posted September 24, 2013 Posted September 24, 2013 Will just be because there is no filter mate if its building boost fine. Quote
Azz Posted September 24, 2013 Posted September 24, 2013 Its called epic noise, this is caused when mesh is used instead of filters because filters suck and ruine noise Quote
pick1 Posted September 24, 2013 Posted September 24, 2013 ^^^^ the man speaks the truth .Sound like the same as mine and mine is meshed Quote
mikey4410 Posted September 24, 2013 Posted September 24, 2013 Running meshed td and its an awesome sound.and the chatter........ohh my god!! Quote
StuDoc 72 Posted September 24, 2013 Posted September 24, 2013 Sounds good I agree but I got far better airflow and more power with a well located filter. Quote
daniel_g Posted September 24, 2013 Posted September 24, 2013 I had a filter for rainy days and when i went up the beach, any other time i had mesh on, noise was outstanding. TD04 Quote
Sandham Posted September 25, 2013 Author Posted September 25, 2013 Im starting to love it now, sounds like a jet taking off lol Quote
Glanza-Ben Posted September 25, 2013 Posted September 25, 2013 Im starting to love it now, sounds like a jet taking off lolWait till it's at 1 bar then it will sound like a jet Quote
