Idrees Posted October 20, 2007 Posted October 20, 2007 Mine points about 5mm under the 0mph but is this suppose to be like this? Should it not point at 0mph when parked still?NA by the way. Quote
Blue Icarian Wings Posted October 20, 2007 Posted October 20, 2007 I believe mine points at zero, take off the clear cover and you can push the needle anti-clockwise until it gets to zero where you want it Quote
Nanglebadger Posted October 22, 2007 Posted October 22, 2007 mine does the same idrees buddy, im just too lazy to fix it and dont wana risk fookin up yet another cluster. its meant to point at 0mph but if u think about it its really not a bad thing, means if its readin 45mph your actually maybe only doin about 42mph or so, can be the difference between points and no points if your misbehavin!Phil. Quote
Mikey Jay Posted October 22, 2007 Posted October 22, 2007 Mine sits a tad below the zero in the Levin too Quote
RobSR Posted October 22, 2007 Posted October 22, 2007 my bros sits on zero.....is yours under it when the ignition is off and on?!?! In other words , does it move up a little when you start it up but are still staionary?!?!Rob Quote
SiCaln Posted October 22, 2007 Posted October 22, 2007 indeed it does because its magnetic, when u start it up circuit is complete and it moves to zero Quote
Mikey Jay Posted October 22, 2007 Posted October 22, 2007 Indeed it does, but I answered about being a tad under zero as assumed Idrees meant when the car is off Quote
Idrees Posted October 22, 2007 Author Posted October 22, 2007 Nope mine doesn't move when I turn the ignition on, it stays here until the car gets moving.. Quote
RobSR Posted October 23, 2007 Posted October 23, 2007 hmmmm, not really sure mate to be honest.....if you are really that bothered (which i would be) pull it off, get a mate to drive along at about 30mph steadily, and then push it back on.....then see if it still does it....by the way, your blue dash conversion looks , did you do it yourself, if so would you mind sharing! CheersRob Quote
Idrees Posted October 23, 2007 Author Posted October 23, 2007 Hmm I'll try to get to the bottom of it when I open the dials up again because the plastics need spraying properly anywayYup did it myself, only done 2 bulbs yet so I'll update properly when I've done all the dashboard Quote
Nanglebadger Posted October 23, 2007 Posted October 23, 2007 nice, I've done mine too!If u want to replace the bubs behind the centre console too its the wee wedge bulbs (type 286) u need. Phil. Quote
stup86 Posted October 23, 2007 Posted October 23, 2007 well mine actually sits a tad ABOVE zero.Maybe my car is just a spaz. Quote
steviet Posted October 23, 2007 Posted October 23, 2007 idress i had the same problem with mine,just pop the needle off and move it to 0 on the dial.It should stay there when you turn on and off the ignition. Quote
Idrees Posted October 23, 2007 Author Posted October 23, 2007 Thanks for your help guys (and Shelly!)I'll give that a try then dude Quote
scutch0 Posted October 23, 2007 Posted October 23, 2007 im pretty sure mine sits over zero... hmmm Quote
Starlet SR Posted October 25, 2007 Posted October 25, 2007 yea mine sits bang zero r u better gettin the coloured bulbs for blue dash convo or jus the sleeves that u can get on flea bay eg. http://cgi.ebay.co.uk/Blue-Silicon-Wedge-B...1QQcmdZViewItemwot u think u guys which wud hav better effect Quote
SiCaln Posted October 25, 2007 Posted October 25, 2007 i tried the bulbs without much success, i found the bigger bulbs over powered the smaller ones and made it look wrong, but i am gna try the sleeves Quote
Starlet SR Posted October 25, 2007 Posted October 25, 2007 i tried the bulbs without much success, i found the bigger bulbs over powered the smaller ones and made it look wrong, but i am gna try the sleevesyea im the same i tryed the led bulbs it over powered the the others as you say so they sleeves r the way 2 go then thanks mate Quote
stup86 Posted October 25, 2007 Posted October 25, 2007 I tried both and sleeves are definately better. Leds are poo.I got my blue bulb covers for ezled on ebay, delivery took 2 weeks. Get them elsewhere if you can. Quote
shelly_star Posted October 25, 2007 Posted October 25, 2007 LEDs are more straight facing than like a wide angle thing, so LED won't be good. How hard is it to get behind the dial? never taken mine apart. Quote
