samcole Posted October 5, 2013 Posted October 5, 2013 I wonder if anyone can help, at the weekend I went to fit a tubular manifold to my glanza, when I was undoing the manifold nuts to the cylinder head, I noticed the stud closest to the gearbox was just attached to a piece of the head what was broken off, it is not leaking oil or anything, just the exhaust is blowing there. Has anyone had this before and can this be welded? Any help will be much appreciated Quote
jimmymac101 Posted October 5, 2013 Posted October 5, 2013 Someone at somepoint has over tightened it and caused this, starletsr? Is in the same situation at the moment sand we had to travel and buy a new head! May pay to invest in a non cracked head James Quote
samcole Posted October 5, 2013 Author Posted October 5, 2013 Thanks for reply, I did think this would be easier but preferd the idea of fixing/ rebuilding mine to save all the hassle of trying to find one. Also obviously I will need to remove the head so will need to replace the gasket, is there a head gasket out there what stands out from the rest or will a id-workz one do fine? Cheers Quote
jimmymac101 Posted October 5, 2013 Posted October 5, 2013 (edited) Id workz would be good choice or a toyota oem one James Edited October 5, 2013 by jimmymac101 Quote
RobSR Posted October 5, 2013 Posted October 5, 2013 You can get it welded if you find a decent welder. if not yea buy another and dont over tighten the studs. Quote
AdamB Posted October 5, 2013 Posted October 5, 2013 You can get it alloy welded if you can find someone who will take the job on, quite a common problem tbh. Cut slots through the webs inbetween the exhaust runners to relieve the stress in the flange. Quote
samcole Posted October 5, 2013 Author Posted October 5, 2013 Brilliant, will strip it down Monday and see if I can find someone to do it, thanks Quote
ryan lang Posted October 5, 2013 Posted October 5, 2013 if you can get it welded, i have a freshly skimmed head at home, did around 400 miles on the engine before i took it back off ryan Quote
samcole Posted October 5, 2013 Author Posted October 5, 2013 Oh really, can you private message me to let me no how much your after for it just encase? Is it built up ready to fit or is it just the bare head. Thanks Quote
ryan lang Posted October 5, 2013 Posted October 5, 2013 its built ready to fit mate. just need yourself a new headgasket. will do mate Quote
Ryan dempster Posted October 7, 2013 Posted October 7, 2013 Porting and polishing cylinder head , Alright guys new to this got myself a glanza v there and it needs a head gasket was wondering if anyone could give me advice on getting head ported and what benifits it would have? Thanks Ryan Quote
AdamB Posted October 8, 2013 Posted October 8, 2013 (edited) Theres no gains to be had unless you know exactly what your doing, power is made or lost at the cylinder head. For this reason is why modifying cylinder heads is an expense job!I don't see the need to touch the cylinder head until 340bhp anyway. Edited October 8, 2013 by AdamB Quote
dai_starletN/A Posted October 8, 2013 Posted October 8, 2013 I had the same problem with my GT I took the head to an engine builder to get it welded back on Quote
samcole Posted October 8, 2013 Author Posted October 8, 2013 Oh really, I got mine back this morning, got it welded and a little brace welded on for £80, done the job Quote
gorganl2000 Posted October 15, 2013 Posted October 15, 2013 Theres no gains to be had unless you know exactly what your doing, power is made or lost at the cylinder head. For this reason is why modifying cylinder heads is an expense job!I don't see the need to touch the cylinder head until 340bhp anyway. i totally agree AdamBproven time and time again Quote
gorganl2000 Posted October 15, 2013 Posted October 15, 2013 just get it welded properlyi've seen it done a few times now without any issues Quote
samcole Posted October 17, 2013 Author Posted October 17, 2013 I have a picture of the repaired head but duno how to upload it lol Quote
Frankieflowers Posted January 27, 2022 Posted January 27, 2022 On 10/8/2013 at 9:34 PM, samcole said: Oh really, I got mine back this morning, got it welded and a little brace welded on for £80, done the job I have the same problem but I really want to try to get it welded without getting the head removed. Is it possible to weld it? Quote
lukEp Posted January 27, 2022 Posted January 27, 2022 Usually this happens due to a warped/none surfaced manifold flange plate and not over tightening, make sure you have the manifold surface checked and if required skimmed as well or you could end up in the same situation after you've fixed it. Quote
