almost every car should be around 750-1000rpm really, just over isnt too bad, your polo sounds like it had a vac leak or something to be that high.
when cold they will idle a little bit higher and settle down to under 1k usually
Edited by morgey
Idle shouldnt be higher than 750rpm
Anybody with half an ear for an engine can tell if its idling to high anyway without the use of a rev counter. Imo 1000 is way to high warm idle and needless
@Mikey when it's cold it's high and loud, once warm it's just over 1k on dials but it's very quiet, so probs the dials are out?
Just wanted to know what people usually average at, always handy to know :)
Also, might be a bit off this topic, I always seem to get a strong smell of petrol from the car. Can't find any leaks or holes, although the exhaust sounds like it's blowing, as if there's a hole in it (new backbox fitted after original one fell off). Any ideas?
Doubt if its the dials mate they were pretty much spot on when they were on my SR the idle did get a bit funky when I fitted a corolla manifold but that was to do with throttle tension I think? :)
I didn't have the bit on the rolla mani that holds the throttle cable properly so I used a bit of rubber to set the tension. Got a bit sticky after a while but I'm sure there was a better way of doing it :)
Can check the accuracy of the dials by popping to a garage with a fairly decent timing light, they tell you what your rpm is, then compare that to what yours read.
Mickey I've not seen any car idle lower than 750rpm I don't think, when they idle that low they sound rough like theyre about to stall
See when it settles, it goes to around 1k and gets rough likes it's gonna idle, so i'm guessing the dials are out? Probs my fault cause I put Paseo needles on :p But I made sure the counter was down and all that?
You could always check does it hit the rev limit at 6500rpm :). If the throttlebody isnt dirty and you havnt messed with anything else it should idle at 750_800. If you bridge te1 & e1 in the diagnostics plug the car will hold idle at 750_800
Use a paperclip or any stiff wire. Youll here your idle valve open up making a swooosh noise then close fully. Your timing is now locked at 10° btdc and your idle should be at the correct. If not adjust your throttle stop.
The most common problem is your throttle is dirty. Clean it with a cloth and your finger while holding open the throttle with your other hand. It shouldnt matter if your throttlecable is loose because the idle should be set spot on from the factory and its usually oily buildup or human error that messes it up. Have u done anything to your car??
  • 1 month later...
For anyone interested, i bridged te1 and e1 and found out its the dials that are off.
If you decide to change your needles on dials make sure you fiddle with them so theyre set properly! :p
