ryan lang Posted October 18, 2013 Posted October 18, 2013 if you have a splash tray you'll have to remove that to get to the bottom ones unless you have 2 elbows on each arm other than that piece of piss. Quote
Glanza-Ben Posted October 18, 2013 Posted October 18, 2013 it took me 20 mins to take cat off and fit decat with all parts in the way, i dout very much the decat will cause you to hit fuel cut Quote
Zeldoz Posted October 18, 2013 Author Posted October 18, 2013 it took me 20 mins to take cat off and fit decat with all parts in the way, i dout very much the decat will cause you to hit fuel cut Boost creep im worried about Quote
Ollieh17 Posted October 18, 2013 Posted October 18, 2013 (edited) i agree,if you are at standard boost i doubt the decat will make you hit fuel cut. Mine creeps and sometimes to fuel cut as i am running slightly over standard boost Creep below fuel cut will not be an issue Edited October 18, 2013 by Ollieh17 Quote
RobSR Posted October 18, 2013 Posted October 18, 2013 Yea its worth having a boost gauge but its not the end of the world for a relatively standard car. Fuel cut is there to stop it going pop remember. Tbh with a filter in the standard location you might be fine and not hit fuel cut. The way around it is either restricting the intake or the exhaust. Just fitting a HKS actuator or Emanage will not sort it. Everyone is saying port the waste gate, which is a ballache of work to take it all off. What you can do, which is easier is fit a restrictor ring in the exahust, which will lower the boost, then raise it backup with a boost controller. Quote
Ollieh17 Posted October 18, 2013 Posted October 18, 2013 Never heard of this before. Does that not go against the point of buying a large exhaust to start with? Quote
Jamie_VF22 Posted October 18, 2013 Posted October 18, 2013 (edited) Jamie.. Any idea on the decat.. boost creep.. engine POP talk above? 1 hour tops to change lad , Boost creep you dont want that pal you will always get it with CT9's due to there age and the abuse people give them and the cracks in the wastegate , Just go for a TD04 set up pal Edited October 18, 2013 by Jamie_VF22 Quote
RobSR Posted October 18, 2013 Posted October 18, 2013 Never heard of this before. Does that not go against the point of buying a large exhaust to start with? Its pretty common, or a restrictor on the inlet which is whats used in WRC. It sort of does go against the point, but so does fitting a larger bore exhaust and hitting fuel cut all the time... Its just another option and easier way than porting the wastegate thats all. Quote
Glanza-Ben Posted October 18, 2013 Posted October 18, 2013 I don't see what the deal is fitting a decat ain't gonna hit fuel cut as won't creap that much Quote
Ollieh17 Posted October 18, 2013 Posted October 18, 2013 I agree. But in future which zeldoz mentioned,with a relocated air filter and FMIC it is likely to creep to fuel cut. Quote
Glanza-Ben Posted October 18, 2013 Posted October 18, 2013 I agree. But in future which zeldoz mentioned,with a relocated air filter and FMIC it is likely to creep to fuel cut. It won't I ran that set up fine at 0.8 bar also again with a hybrid and no fuel cut and my mate who you got the decat off ran that set up Aswell Quote
Ollieh17 Posted October 18, 2013 Posted October 18, 2013 (edited) weird, because 4 and 5th i hit fuel cut (very rarely though). and have standard intake, arc topmount, hks actuator boost set to 0.7bar, the decat and jpeformance catback. Edited October 18, 2013 by Ollieh17 Quote
Zeldoz Posted October 18, 2013 Author Posted October 18, 2013 It won't I ran that set up fine at 0.8 bar also again with a hybrid and no fuel cut and my mate who you got the decat off ran that set up Aswell I've deicded to put it on tonight. We're see how it goes... Quote
Glanza-Ben Posted October 18, 2013 Posted October 18, 2013 weird, because 4 and 5th i hit fuel cut (very rarely though). and have standard intake, arc topmount, hks actuator boost set to 0.7bar, the decat and jpeformance catback.What's your turbos condition? Any cracks in wastegate? Quote
Addymk2 Posted October 18, 2013 Posted October 18, 2013 You can port the wastegate yourself mate, pick up a cheap dremmel and just be careful not to go too far. A good ebc can help aswell or just pick up a plug n play ecu Quote
Zeldoz Posted October 18, 2013 Author Posted October 18, 2013 What's your turbos condition? Any cracks in wastegate? I dont know his, but mine is on 82,000 KILOMETERS. Geniune mileage?.. So i would presume it would be in an ok condition also? Quote
Ollieh17 Posted October 18, 2013 Posted October 18, 2013 haven't had it off, probably not in the best of conditions. Have been toying with swapping it out for a td04 Quote
Glanza-Ben Posted October 18, 2013 Posted October 18, 2013 When the cats off just have a look at the wastegate and check for play in turbo Aswell haven't had it off, probably not in the best of conditions. Have been toying with swapping it out for a td04Td04 is the way to go Quote
RobSR Posted October 18, 2013 Posted October 18, 2013 It won't I ran that set up fine at 0.8 bar also again with a hybrid and no fuel cut and my mate who you got the decat off ran that set up Aswell Hybrids usually have ported wastegates which is why that wouldnt of crept. Quote
Glanza-Ben Posted October 18, 2013 Posted October 18, 2013 Hybrids usually have ported wastegates which is why that wouldnt of crept.Yea I know, have had two ct9's stock with decat and neither hit fuel cut either Quote
RobSR Posted October 18, 2013 Posted October 18, 2013 I see, well they are all different so you must of been a lucky one! Quote
