First turbo starlet and i have no clue. I got the car standard (turbo, top mount ) and it whistled loads thru the turbo. Since intercooler is on still does it. Is that normal? Sound of turbo spooling? Sounds like a jet lol. Changed knock sensor aswell and it feels different. Boost dont fully kick till like 5.5k and feels likes its holding you back. I havent even coverd the high and low boost tubes there just open. Do they need to be blanked off?
Thanks guys ill crack some in the morning. Shouldnt it be that loud spooling then? I know i should blank the hi and low tubes off i havent done that
turn the boost down first.
sounds like a boost leak. these standard turbo'd are getting on a bit now so the housing seals will start to be perishing etc. best thing to do really is either get another one second hand or buy a recon'd turbo.
or recon your own if you can
  • 4 weeks later...
Fixed the intercooler and now have no leaks what so ever. But yet still doesnt boost corrrctly. I so found i got like a 2 inch crack in the manifold. Will this not help it? Do think its the seals aswell,
Yeah, a crack will reduce boost dramatically and will cause all kinds of boost issues really dude. Get pauls set up asap :p.
