andy91145 Posted November 19, 2013 Posted November 19, 2013 Right this is a bit of an odd question I'm after a plug and play but I have a sneaky suspicion I may already have one in the car because of the following reasons.- It does not appear to fuel cut at 113mph- I have not had a boost fuel cut in high boost which reading peoples comments would happen if I had a stock ecu due to boost creep:-Mods are Full turbo back Japspeed Meshed turbo (CT9)Large FMICDecat and custom manifold Is the ecu easy enough to get at on an EP82 really want to see if it is just stock or not Quote
Chris Green Posted November 19, 2013 Posted November 19, 2013 I think the ECU is behind the glove box, you should be able to pop it out and have a gander. Get some photo's while your there. Quote
_shaun_ Posted November 19, 2013 Posted November 19, 2013 its not on the ep82 its behind the center console. if u go in fron driver side foot well u should be able to see it its ment to be in a black plasic box but thats likely been removed if its aftermarket Quote
andy91145 Posted November 19, 2013 Author Posted November 19, 2013 I think the ECU is behind the glove box, you should be able to pop it out and have a gander. Get some photo's while your there it's behind the glovebox I think the ECU is behind the glove box, you should be able to pop it out and have a gander. Get some photo's while your there.Think it will have to be done, I'm assuming the standard on will just have toyota and 4efte on etc?Will get photos as well Quote
Gainzy Posted November 19, 2013 Posted November 19, 2013 Big bonus if you have an aftermarket! It will have stickers on it from a different company ad be out there now looking lol Quote
morgey Posted November 19, 2013 Posted November 19, 2013 after market usually have security tabs over the front onto the side to stop them from being tampered with. stock just has a large sticker with 4efte M/T or A/T and a picture of the plugs at the bottom Quote
andy91145 Posted November 19, 2013 Author Posted November 19, 2013 Big bonus if you have an aftermarket! It will have stickers on it from a different company ad be out there now looking That's exactly what I've gone and done, I can't see a great deal although it's not looking good as the black plastic cover appears to still be there just going to pull the dash out and have a proper look Quote
andy91145 Posted November 21, 2013 Author Posted November 21, 2013 So after all that turns out the ecu is standard time to get hunting for a plug and play Quote
Gainzy Posted November 21, 2013 Posted November 21, 2013 So after all that turns out the ecu is standard time to get hunting for a plug and playNooooo Quote
andy91145 Posted November 21, 2013 Author Posted November 21, 2013 Nooooo A tad gutted to be honest just shows how wrong my speedo is :') Quote
Gainzy Posted November 21, 2013 Posted November 21, 2013 A tad gutted to be honest just shows how wrong my speedo is :')Look into the EManageUltimate Quote
andy91145 Posted November 21, 2013 Author Posted November 21, 2013 Look into the EManageUltimate bit expensive at the moment it was a standard car just finished all the turbo supporting mods Quote
Gainzy Posted November 21, 2013 Posted November 21, 2013 Totally understand leave the map till last I suppose makes sense Quote
Sefton-EP91 Posted November 21, 2013 Posted November 21, 2013 (edited) What about EMB? A lot cheaper than ultimate EMB can be brought for near on same price as a P&P ECU including mapping, I have a p&p on ep91 and debating the switch to EMB or EMU. It's so better because you are creating a specific map for your setup. And easily adjusted when you decide to do more mods. Whereas the P&P cannot be adjusted. Edited November 21, 2013 by Sefton-EP91 Quote
Gainzy Posted November 21, 2013 Posted November 21, 2013 What about EMB? A lot cheaper than ultimate, I have a p&p on ep91 and debating the switch to EMB or EMU. It's so better because you are creating a specific map for your setup. And easily adjusted when you decide to do more mods. Whereas the P&P cannot be adjusted.I always stuck by if the stock turbo's goes give up the p&p, the p&p still self learns plus you don't have another ecu hanging around the footwell etc the only way to know is to have a dyno see what's going on... Quote
micky boy Posted November 21, 2013 Posted November 21, 2013 Thats the pluss side of a p&p you can just plug them in on a stock car just to stop fuel cut mainly Then you can start putting mods on over time and the ecu will self adjust to them mods! Where as with the emu etc you have to get it mapped everytime you change something on the car Quote
