Need a good head gasket a thick steel one becaus standard gasket keeps blowing between cylinders.
Changed head gasket twice and each lasted 3hrs
Why does it only last 3 hours? Who fitted them and did they use new bolts?
We stock new MLS head gaskets but you need to know what going wrong before upgrading it mate.
If the head has been skimmed and new bolts fitted and torqued down correctly then you must have a warped block.
How are you cleaning the block up before placing the new gasket on?
Agreed
I rub the face down so nice and clean and don't use any sealent ?
The gasket goes between cylinder 1 and 2 it's blows a inch gap so then there's no compression on 1 and 2
Chances are you've warped the block by doing that I'm afraid mate. You'll want to get the block decked now which will most probably be an engine out job.
I've warped the block by doing what rubbing it down with a flat disk on a block ?
I'm not expert in this.. But surely you could of.. If you applied more pressure one end, and less the other it will rub deeper and therefore warp it?
Feel feel to ignore this post if its all wrong lmao!
Get a steel ruler and feeler gauge and take measurements all over the surface of the block make sure you write it down, then compare the results from in between each cylinder against each other I'd say 0.0020mm is the max limits of play any more and I'd say it needs re decking, I could be out in the measurement but a quick Google could confirm that
For future reference, the torque settings for oem headbolts are relavtively low and can cause the hg to not be sealed proper.. they should be 30% more for the small bolts and 40% more for the longer bolts.
Dunno if it helps but bear it in mind when puttin it back together!
