Hello hello
I'm After opinions on 'omex rev limiter & launch'
Not going to lie, just want my car to go bang & pop flames.
You may say it's childish, stupid & pointless but honestly I own my Glanza for enjoyment.
All opinions welcome
Any one have any genuine evidence that this happens cause got a pal who runs this on his, has done for a while now and his is still running 200+ bhp on the ct9
No problems what so ever
There is no evidence that it will happen
Its like running lean, people do it for years and they are absolutely fine. Just cause you run lean you wont fuck your motor
just cause you run a hard cut limiter you wont crack a piston. but its a contributing factor, and you should be aware of it.
You asked for opinions, so your getting them. If you want to run it that bad, then youll do it anyways despite the risks. in that case go for it, just be aware that damage can occur
Thank you buddy, I appreciate your advice and honest opinion :-)
I think I may try it at a later stage.
One thing I recall is, my mates V struggles to pop/bang on the launch controll only pops when revved up to 6k rpm.. I guess it's cause he doesn't have a Fpr?
There are different types of rev limiters soft/hard cut limiters, the hard cut limiters are where it cuts the ignition for longer(more chance for more fuel/air to enter combustion camber) making a big bang and the reverse is for the soft cut limiters. There are many adjustable ones On market
Bolted it on, it's pretty awsome! It doesn't bang when on launch though.
Only bangs when at 6k rev limit.
Launch set at 4k which is just right, spool to take off without spinning up too much 👌
£100 well spent
Lol just don't abuse it as you are burning your exhaust valves, I have launch control on my dc2 and it's fucking insanely loud. The temptation to do it is hard to resist mind lol hang on I will find a vid
http://i1017.photobucket.com/albums/af291/marc7680/7AB73050-3802-408D-B188-FCC6A87274C1_zpsfxcczasx.mp4
http://i1017.photobucket.com/albums/af291/marc7680/74D47A4A-7915-4AC6-98C9-568C40DF8642_zpsbtuao7sy.mp4
for the best launch possible ??
thats maybe a little bit of fantasy but it will hold the revs at 4k as long as you want it too.
thats about it.
Phil
