SevyjackSR Posted December 3, 2013 Share Posted December 3, 2013 I've removed my old steering wheel on my EP91 98 starlet 1.3 (not glanza) and put new one on however I now have a warning light saying I have no airbag because it was removed with the old steering wheel any ides how to get rid of the warning light ? Quote Link to post Share on other sites
wssoR Posted December 3, 2013 Share Posted December 3, 2013 Needs to be reset Quote Link to post Share on other sites
SevyjackSR Posted December 3, 2013 Author Share Posted December 3, 2013 What you mean reset ? Can you give me some steps on what to do ? Quote Link to post Share on other sites
daniel_g Posted December 3, 2013 Share Posted December 3, 2013 Take the bulb out. Quote Link to post Share on other sites
morgey Posted December 3, 2013 Share Posted December 3, 2013 Reseting it won't do shit if there's no airbag there.For the mot your airbag light must act as normal, come on with ignition then turn off, so you have to fool the system into thinking there's an airbag there.This can be done by a simple resistor block or just head toWww.dashlightremoval.com (i think that's the site) Quote Link to post Share on other sites
SevyjackSR Posted December 3, 2013 Author Share Posted December 3, 2013 I've tried that took all the HUD out but couldn't get round the back of the gauges to get at the bulb, seemed although the cables behind were tight and couldn't pull it out, debated pulling the whole dash off to get at it is that the best way ? Quote Link to post Share on other sites
daniel_g Posted December 3, 2013 Share Posted December 3, 2013 If there is no airbag then you dont need an airbag light. For MOTs you cant test what isnt there, generally anyway. Quote Link to post Share on other sites
SevyjackSR Posted December 3, 2013 Author Share Posted December 3, 2013 Cheers morgey Quote Link to post Share on other sites
morgey Posted December 3, 2013 Share Posted December 3, 2013 If there is no airbag then you dont need an airbag light. For MOTs you cant test what isnt there, generally anyway.Pretty sure now if the car came fitted with an airbag,whether its there or not, the airbag light must work. Bit like cats.I might be wrong on that though. If that is the case then yeah just pull the bulb out lol Quote Link to post Share on other sites
akyakapotter Posted December 3, 2013 Share Posted December 3, 2013 maplin resistor is like 30p ish Quote Link to post Share on other sites
SevyjackSR Posted December 3, 2013 Author Share Posted December 3, 2013 Thought It might be just a simple as a resistor I'll try that see where I get if not have another look at pulling the bulb out thanks for help guys Quote Link to post Share on other sites
Starlet-Joshy Posted December 9, 2013 Share Posted December 9, 2013 Can you not take the fuse out?, I presume the light is supposed to come on if the fuse is out to show that there is no airbag connected, however when i took my fuse out the light went off, try that mate?My apolagise if you already have lol, just incase Quote Link to post Share on other sites
SevyjackSR Posted December 19, 2013 Author Share Posted December 19, 2013 Haven't tried that I will do bud cheers Quote Link to post Share on other sites
hookie663 Posted December 20, 2013 Share Posted December 20, 2013 i had same hasel mate i took bulb out lol Quote Link to post Share on other sites
