  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
Get socks to sell you his or get his spec list and go wild with the credit card :)
Its all in his build thread fella.
Same exhaust as mine, full 3" turbo back by racetech almost £700
It's fitted properly bud, was told there should be adjustment in the v-band join but it appears not! Does sound immense though all the same! :)
Picked mine up from Race-Tech perfect..
Ive had the system off twice to clean it/clean under the car/underseal the shell.. etc
Had to go back to a local garage with a ramp to get it right and to stop it knocking...
There is a lot of adjustability in an exhaust, even with flange joints.
Its a HUGE exhaust pipe to fit over a rear beam. The sweetspot/gap is a small one, but I can get mine perfect. :)
Ive been able to get it perfect without a ramp since too...
Could just try fitting it properly :rolleyes:
Same car running a tad more boost:
Skimmy, have a perv thru the build thread if you are wondering about spec...
I love this video ! It sounds perfect ! I take it that it's forged from all that limiter banging ?
Simple question, am I going to wreck an apexi exhaust by taking the silencer out the middle ?
Would be easier to get a new center section... THen your not ruining any exhaust...
PM Dean @ RW Developments... He will hook you up!
