smb2011 Posted December 17, 2013 Posted December 17, 2013 Down a 1/4 mile what would finish first and do a better time matching bhp just one with normal flywheel and one with a lighten one ? Much differents ? Worth paying the money for one? Quote
H_D Posted December 17, 2013 Posted December 17, 2013 A lightened flywheel should help it rev up faster but the revs will also drop faster between gear changes Quote
Mikeyallgood85 Posted December 17, 2013 Posted December 17, 2013 I'll let you know when mines fitted tomorrow :-D I wouldn't have thought that it would drop down the Rev's faster as it's lighter, I would of thought it would spin slightly faster and more freely when the clutch is disengaged due to not having as much weight resistance! Quote
Phil Posted December 17, 2013 Posted December 17, 2013 I'll let you know when mines fitted tomorrow :-D I wouldn't have thought that it would drop down the Rev's faster as it's lighter, I would of thought it would spin slightly faster and more freely when the clutch is disengaged due to not having as much weight resistance! nope quite the opposite unfortunately. Phil Quote
H_D Posted December 17, 2013 Posted December 17, 2013 I'll let you know when mines fitted tomorrow :-D I wouldn't have thought that it would drop down the Rev's faster as it's lighter, I would of thought it would spin slightly faster and more freely when the clutch is disengaged due to not having as much weight resistance!The rotational mass on stock flywheel is heavier. Quote
mattyD Posted December 17, 2013 Posted December 17, 2013 I found mine a bit of a waste of money, revved ever so slightly quicker and that was about it, money can be spent elsewhere for far more gains Quote
Mikeyallgood85 Posted December 17, 2013 Posted December 17, 2013 The rotational mass on stock flywheel is heavier. so the weight of the standard flywheel keeps the crank spinning because of the extra kg and the engine does the opposite with the lighter flywheel by creating more resistance? Quote
Phil Posted December 17, 2013 Posted December 17, 2013 so the weight of the standard flywheel keeps the crank spinning because of the extra kg and the engine does the opposite with the lighter flywheel by creating more resistance? your engine spins either, up to the point you lift off the throttle at that point the rotational weight of the flywheel governs how quickly it will slow down. heavy slows down slower lighter slows down faster. much like a freewheeling lorry wont slow down as fast as a unmaned tricycle. Phil Quote
Mikeyallgood85 Posted December 17, 2013 Posted December 17, 2013  your engine spins either, up to the point you lift off the throttle at that point the rotational weight of the flywheel governs how quickly it will slow down. heavy slows down slower lighter slows down faster. much like a freewheeling lorry wont slow down as fast as a unmaned tricycle. I learn something new everyday ;-) well explained Phil interesting stuff I'm looking forward to feeling the difference!  Phil Quote
Thomastaylor Posted December 30, 2013 Posted December 30, 2013 I have my competition flywheel and organic Exedy clutch to fit soon so will be interesting to see if it makes much difference Quote
smithyithy Posted December 31, 2013 Posted December 31, 2013 Would you notice the effect of engine braking more with a lighter fly wheel? Quote
Jamie1st Posted January 2, 2014 Posted January 2, 2014 To me the car felt a lot 'lighter' to drive, I like mine Quote
monty1991 Posted January 2, 2014 Posted January 2, 2014 all i noticed was the car turned over faster on start up lol Quote
Arnold Posted January 6, 2014 Posted January 6, 2014 No complaints with mine, I've got the Fidanza one. A worthwhile mod if you've got a larger turbo as it helps get to higher revs faster to spool the turbo Quote
Chris_GlanzaV98 Posted January 6, 2014 Posted January 6, 2014 Im running spec 6 clutch and flywheel but mine went from like 170 to 280 hp and these parts were fitted so hard forMe to single out just the flywheel, although it idles pretty fast on cold startup Quote
