If you go low boost, 0,5bar, then you only need 4efte injectors, and mapconverter (37pounds)
whats this map converter can you not just run emanage ultimate on the stock 4efe ecu
need to change pistons and conrods to forged ones. and that alone already costs ££££ or (€€€€, depending where you live! haha)
The above is wrong regarding rods
Glanza rods are same as n/a rods for sure.
Cranks usually same also.
good morning
so you are stating that you can safely stick a stock turbo and all stuff from a 4efte straight to a 4efe?
thanks
good morning
thanks
yes you can i ran a 12psi ct9 on the ( ep82 GI block ) then blew my cheappo chinees gasket after 10.000km then fitted toyota oem 1 and never blew again
the gen 2 engines will take less boost
Edited by 5e colin
I have a 4efe Irish engine same inlet as turbo not the tubular one 76,000 miles on it since new would this be a candidate to run the turbo setup
I can source all the bits I need.. ct9 turbo/oil feed/exhaust system/intercooler/
bits I don't have any info on is wiring I don't want to fit the whole turbo loom as then I could just go for the full 4efte running gear
and this map converter I've never seen one or even heard of it
