Flintygt Posted January 4, 2014 Posted January 4, 2014 Hi all, I have been think about removing my power steering power. There is a chance that I may be racing the gt next year. A few question Has any one had any problems with it if is there daily? ( I only have a 10 inch steering wheel) What is the best way to remove the pump? Many thanks Flint Quote
morgey Posted January 4, 2014 Posted January 4, 2014 i hate mine with it removed but i had no choice. to heavy for daily imo even with the stock size S/wheel, If you can source a non powersteering rack then i would do it that way as it wont be as heavy as a P/S rack with the pipes looped like mine. Quote
Flintygt Posted January 4, 2014 Author Posted January 4, 2014 Thank for the advise dude. Maybe not a great idea then :/ Quote
morgey Posted January 4, 2014 Posted January 4, 2014 not unless you are doing it properly. im planning on putting an electric pump on mine when i can/get around to it. some people love it though. if you get the right fittings and get a length of pipe made you could loop the rack over and see, if you like it take the rest off if you dont reconnect it and put new fluid in. Quote
Beastmode panda Posted January 6, 2014 Posted January 6, 2014 Just fucking grow a pair and take it off lol. It's not like you're going to be pulling a tanks weight around on the steering wheel, yes it's a little bit heavy but it's saves a hell of a lot of weight and it's not needed what so ever. Literally as soon as you're rolling, the steering nearly the same as with power steering. I was steer with one hand fine round corners. The stress it will save from the engine is also noticeable, as obviously the engine isn't working as hard. Bun a non PAS rack too, just take it all off and chuck a loop on there. Simple. Quote
Chand Posted February 7, 2014 Posted February 7, 2014 Is it as simple as swapping power steering rack to a n/a steering rack Not have to change anything else? Quote
richardc9052 Posted February 7, 2014 Posted February 7, 2014 What size belt would you run when you remove the power steering pump? I also dont have A/c pump Quote
richardc9052 Posted February 7, 2014 Posted February 7, 2014 so the alternator belt is seperate? i have not paid much attention the the aux belts yet. thanks Quote
Glanza-Ben Posted February 7, 2014 Posted February 7, 2014 so the alternator belt is seperate? i have not paid much attention the the aux belts yet. thanksYea the alternator is on a separate belt that goes to the back if the engine, the 1st belt does power steering and air con if you have it Quote
lew777 Posted March 19, 2014 Posted March 19, 2014 Any more info on this I'm looking to remove mine. Quote
Beastmode panda Posted March 19, 2014 Posted March 19, 2014 Any more info on this I'm looking to remove mine. What else you want to know mate? Quote
Idrees Posted March 19, 2014 Posted March 19, 2014 Any more info on this I'm looking to remove mine. From experience I would say only do this if you're going to use a non P/S rack Lew. I looped the pipes on my old Glanza and it was horrible to drive. Quote
mikey4410 Posted March 19, 2014 Posted March 19, 2014 as rbz says.removed mine on ever starlet I have had as its just not what I want on the car.weight, drag on engine, steering feedback, and worst of all its fuck ugly and u cant get to anything properly in engine bay.car is perfectly manageable without it .these are light cars !!!! Quote
morgey Posted March 19, 2014 Posted March 19, 2014 I've been making due with out mine for about 4 years and have never really liked it. I'm soon going to be experimenting with a MR-S electric/hydraulic pump as a replacement for the pulley driven one.With any luck I can get the speed variable aspect working as well Quote
JLF88 Posted March 19, 2014 Posted March 19, 2014 Was driving a mk2 golf the other day without pas and it felt so much better. I can't wait to find a non pas rack and get rid. Question is though, do you need to change the column as well? Quote
akaye4000 Posted March 19, 2014 Posted March 19, 2014 I removed it and have a saxo electric pump instead on a switch so can just turn it on for parking:) works a treat Quote
