hi, just wondering what the max horsepower is that you can get from a ct9 turbo? and whether its worth going for a td04? if so what price would a td04 set up all in cost? cheers
Some guy pulled 215 from the ct9 it's not all about the td04 I think there over rated unless your going forged and pushing the boost up :)
Up to 200 @ 1bar on CT9 and all depends on what you are looking to achieve
Decent TD04 set up up to £1000 second hand, £1300 new another £250-£500 management then £250 for mapping would see around 235bhp @1bar on TD04
John
Edited by ro55ifumi
Thanks Guys! think ill stick to the Ct9 atm and save up for a Td04 later on! whats the best management to use on a ct9?
So over a grand for 20bhp....rather strip it out and make the handling top notch imo, plug n play ecu will do the job for the ct9 set up then sell it when you go td04 as the plug n plays keep their value all day :)
Or you could get the stock ecu mapped but when you come to the td04 fitment you will need to map it again so that's a few journeys you can't lose either way lol
yeah not worth going td04 just yet! Would you get the same results if you map the stock ecu? rather than buying a plug and play ecu?
You can't .map the stock ecu and pnp are around £500
John
cheers! okay so say i get a blitz access ecu would that work on my ct9?
yeah it would be fine, you can run a td04 on one as well if you ever decided to upgrade later on! You'll need to get it on the rolling road to make sure it's fueling correctly though to be on the safe side!
My CT9 did 190hp, and my TD04 is 217. The cost to get that extra 30hp was loads, but the way it drives is totally different. TD04 seems to be more fuel efficient too as it boosts later up the rpm.
Also, you can use a piggyback ECU - emanage blue or something, cheaper than standalone but better than the FCD/RRFPR etc route. Tuning Developments do mapping, and sell TD04 kits but make sure they have improved the manifold design. Mine and others have cracked in half.
Edited by Arnold
Okay 190 bhp sounds good enough! would you recommend spending the money and going for a tdo4 tho? so whats the difference between a piggyback ecu and a e-manage blue then??
Cheers!
  • 2 weeks later...
Ive got td04 and ive been in a ct9. So ill say have you considered the k24 or the tf035. These are still good for over 200bhp. But with much better spool up. Just something for u to consider rather then a td04
Thanks Turk I've been reading this as I am in the same boat as euan. Can't afford a TD04 quite yet. Sorry to hijack quickly euan but what car is the tf035 from?
if you choose to change turbo set up then you will have to change mani/down pipe set up i would only ever use a zisco or wepr set up as all the rest crack...personally i'd stay away from the blitz and mines,etc ecu's they're preprogrammed to another persons set up..people say they're self learning is a crock of shit go for either a e-manage ultimate or if you have a dastek tuner near by go for one of those ...the beauty of the td04 is they are plentiful and cheap!!;),td04 go for 1 bar on standard internals..but if you are upping the power DO NOT FORGET TOO UPGRADE THE BRAKES!!!..:)
Go for a TD/VF series setup, start with a TD04, if you find it too big (doubt it) you can put on a TF035 turbo which is slightly smaller, or swap on a VF series turbo for more power, there is a huge range to choose from, and of course TD05s aswell. The best thing about these kits is the turbos are all the same flange (99% of the time)
Can personally vouch for Zisco kits :)
