Haven't heard of one as of yet mate it's definitely something that needs doing the only trouble is the handbrake cable
Edited by JordanEP91
I've got a bias valve ready, competing with the car do I'd say it's crucial to set the car up how I want it to drive
I'd say it's crucial so I can set the car up how I want it *
agree something for the rear brakes is needed, noticed once i put 4 pots on the front the back end goes twitchy when breaking hard, guess where the breaking balance is out now
Fit the same pad material to the back as you have on he front, make sure your rear disks are fresh, do away with the standard proportioning valve and fit an adjustable one.
The only time you really need to shift your braking around once it's set is if it's wet out, bigger rear brakes are unnecessary.
Fiat turbo calipers and astra discs, you have to get a small amount machined from the inside of the disc.
Think there was a thread on tgtt
We're planning on doing a rear kit, but it's a way off yet I'm afraid.... :-/
what about the celica caliper setup?
sorry for hijack?
Phil
Contact sacha at wepr Im sure I seen a thread about uprated rear brakes being fitted to one of his cutomers glanzas.
