Tobyb94 Posted February 17, 2014 Posted February 17, 2014 Is quaife the only place where you can get sequential gear box Quote
DevonGT Posted February 17, 2014 Posted February 17, 2014 (edited) If it's for a starlet, then Zisco performance might be able to help. Also ECC have got one running in a starlet. Edited February 17, 2014 by DevonGT Quote
Stu Posted February 17, 2014 Posted February 17, 2014 Are they a sequential box? I thought the most ones were just a sequential shifter assembly? Quote
Azz Posted February 17, 2014 Posted February 17, 2014 (edited) I think you mean dog box maybe ?I've been in talks about the zisco one with people who are running them and unless your only on track/drag strip there no good totally ruin the car on roads as would any other dog box.Stock ones are proven to around 400bhpAnd as above its just a sequential shifter if that's what your talking about and there around 2000 from zisco Edited February 17, 2014 by Azz Quote
AdamB Posted February 18, 2014 Posted February 18, 2014 No such thing as a sequential gearbox. You either have a synchro mesh gearbox, or dog engagement box either can have helical or spurred gears.A sequential shifter is just the shifter assembly, even with a synchro mesh engagement though you will still have to use the clutch going up and down gears (unless you heel and toe of course). With dog engagement you can shift up without using a clutch. You can use the Ikeya shifter from the Evo if you want a sequential shifter but is pointless imo. Quote
Chris_GlanzaV98 Posted February 18, 2014 Posted February 18, 2014 All things being equal it would be cool as foock on a trag breif Quote
jordan walker Posted September 30, 2014 Posted September 30, 2014 No such thing as a sequential gearbox. You either have a synchro mesh gearbox, or dog engagement box either can have helical or spurred gears.A sequential shifter is just the shifter assembly, even with a synchro mesh engagement though you will still have to use the clutch going up and down gears (unless you heel and toe of course). With dog engagement you can shift up without using a clutch. You can use the Ikeya shifter from the Evo if you want a sequential shifter but is pointless imo.How much do you know about them ikeya shifters?Are they easy to fit i.e do you have to modify them much or is it a straight fit? Quote
Socks Posted September 30, 2014 Posted September 30, 2014 I think you mean dog box maybe ? I've been in talks about the zisco one with people who are running them and unless your only on track/drag strip there no good totally ruin the car on roads as would any other dog box. Stock ones are proven to around 400bhp And as above its just a sequential shifter if that's what your talking about and there around 2000 from zisco Wouldn't say they were proven... Ive striped 3rd gear at 340bhp.... Id say 300bhp is there comfortable limit... Quote
morgey Posted September 30, 2014 Posted September 30, 2014 Dont know if its actually doable but the fwd 4agte lot upgrade there C series (what we all run) to the gearbox that the supercharged 4agze came with which is an E series. That bolts upto the 4a engine. Not sure if it would be possible to swap bell housings to suit an E series but maybe something to look at but they run excess of 5-600hp through them Quote
5e colin Posted September 30, 2014 Posted September 30, 2014 we are lucky to have a sequential from factory on the mr2 ( new ) have a read http://www.caranddriver.com/reviews/toyota-mr2-spyder-smt-short-take-road-test Quote
Hunty Posted September 30, 2014 Posted September 30, 2014 Rossport sell the evo ikeya shifter iirc not sure on the price though Quote
jordan walker Posted September 30, 2014 Posted September 30, 2014 I found some earlier for about 900 quid I was just wondering if there's much of a fuck on trying to get them to fit a starlet or if its easy Quote
jordan walker Posted September 30, 2014 Posted September 30, 2014 http://www.ebay.co.uk/itm/IKEYA-FORMULA-SEQUENTIAL-SHIFTER-MITSUBISHI-EVO-4-9-CP9A-CT9A-CN9A-IFBJ02002-/140928079747?pt=AU_Car_Parts_Accessories&hash=item20cff7d783These ones by the time you add postage like it works out closer to a grand but still cheaper than what rosssport sells them for at 1200 Quote
5e colin Posted September 30, 2014 Posted September 30, 2014 I found some earlier for about 900 quid I was just wondering if there's much of a fuck on trying to get them to fit a starlet or if its easy not easy our bel wont bolt on to that box cut and weld job or adaptor plate then al the electronics like the ecu etc etc Quote
AdamB Posted September 30, 2014 Posted September 30, 2014 How much do you know about them ikeya shifters?Are they easy to fit i.e do you have to modify them much or is it a straight fit?I have seen someone over on TGTT use one but I can't remember about the fitting, worth a search over there. As far as what I can remember it wasn't too much hassle as the shifters aren't too dissimilar. Quote
5e colin Posted September 30, 2014 Posted September 30, 2014 http://www.ebay.co.uk/itm/IKEYA-FORMULA-SEQUENTIAL-SHIFTER-MITSUBISHI-EVO-4-9-CP9A-CT9A-CN9A-IFBJ02002-/140928079747?pt=AU_Car_Parts_Accessories&hash=item20cff7d783 These ones by the time you add postage like it works out closer to a grand but still cheaper than what rosssport sells them for at 1200 we need a trader on ere to do a group buy on them for 200/250 :) Quote
jordan walker Posted September 30, 2014 Posted September 30, 2014 I have seen someone over on TGTT use one but I can't remember about the fitting, worth a search over there. As far as what I can remember it wasn't too much hassle as the shifters aren't too dissimilar.Cheers man ill have a mooch now we need a trader on ere to do a group buy on them for 200/250 :)^^^^^^^ YESSSS! Quote
jordan walker Posted September 30, 2014 Posted September 30, 2014 http://www.toyotagtturbo.com/forums/showthread.php?106513-ECC-Modified-Ikeya-Sequential-Shifter-For-Toyota-Starlet&highlight=IkeyaThis seems to be the only promising thing I can find over on tgtt. It seems that ECC modified one but never shown how they did it I'm presuming its because they planned on selling a couple of modified ones and making a bit of moohlah :/Think ill drop ECC a message and see if I can get any details off them Quote
jordan walker Posted September 30, 2014 Posted September 30, 2014 Yeah I seen someone had mentioned that on tgtt but yet again I couldn't seem to find anything else about it other than someone mentioned that he used to run one I looked for a build thread on here and couldn't find one and the build thread on tgtt just had pics of when he initially bought the car Quote
AdamB Posted September 30, 2014 Posted September 30, 2014 Contact Keith at Zisco as well mate, I'm sure he knows of a couple of the lads over in Malta that run the Ikeya Evo shifter in a Starlet as I'm sure i've spoken to him about them before. My mate runs one in his Evo and it's good but does get a bit tedious, I probably wouldn't advise using one if its your daily car. Quote
Hunty Posted September 30, 2014 Posted September 30, 2014 Yeah definitely not on a daily gary @ AP Tuning is a wizard at setting them up on the evos so it might be worth having a word with him he might be able to help Quote
jordan walker Posted September 30, 2014 Posted September 30, 2014 Cars not going to be a daily its going to be a track toy/bit of weekend fun every so often so should get away with one ill give him a shout cheers guys Quote
AdamB Posted September 30, 2014 Posted September 30, 2014 That's good to hear mate! They are annoying you still have to clutch on the way up, but on the downshifts they are quality (if you can heel and toe). Quote
jordan walker Posted September 30, 2014 Posted September 30, 2014 Yeah they are pretty cool like I would love one if I can find one at a reasonable price if not ill just give it a miss Quote
