point is fhe rods and fte rods will take whatever boost a td04 can give them indefinitely with a good tune.
No chance a td04 needs the sort of revs that would try a fhe/fte rod (with a good tune)
So your rods arent a limiting factor.
Phil
Edited by Philm
4BAR you can't be serious...
Big boys run 8 lol
Was waiting for a pic to load up in that space haha. No i dont run 4 bar, and to the OP not that many folk run FHE rods but they are thick as fuck and i bet the ringlands will go waaaaaaay before FHE rods fail.
So just turn the boost up and up until it gets sketchy or stops making power
Haha you've picked up on the joke in this thread.
Seriously 5efhe rods can take whatever a td04 can give them within the standard rev limit
Phil
You dont need to worry about the rods, they will probably be the last thing to break.
I was joking when i said 4 bar.
1.2 bar or whatever will probably be a good pressure to run, but it also depends on what comp ratio you have, octane of fuel used etc.
  • 2 months later...
ok then i have decided to run 1 bar on my (5efhe>to>5efte)
can any one help me with this prob??
if i run a high comp boosted engine(5efhe stock) how much max boost i can put through a tdo4-hl?
Depends where/when the engine starts to knock, get it well set up and see how far it can be safely taken.
whats sort of fuel you running?
Phil
that great thats how budget 5efte is build 1 to 1.1bar will do the job :) :) try to get the 93/95 ron stay clear off the 80 stuff or it will nead a full remap to suit the crap feul !!!!
keep an eye on det to !!!
