Kai_ethan Posted March 13, 2014 Posted March 13, 2014 I'm running a td04 at 0.6 bar ATM waiting to get mapped car is currently off the road, my current breather system is just a filter on the rocker breather and then the standard Pcv vavle, do I need to upgrade this at all? And what the benefits? Quote
evo Posted March 28, 2014 Posted March 28, 2014 No you don't need to change this. Keep the PCV valve if it's a daily driver as this will help the engine last longer and the filter can be left as it is or you could run a pipe to a catch can if you like but it's not really necessary unless you're getting a bit of oil residue around the filter and want to keep it clean. Quote
JayJ Posted April 14, 2014 Posted April 14, 2014 No you don't need to change this. Keep the PCV valve if it's a daily driver as this will help the engine last longer and the filter can be left as it is or you could run a pipe to a catch can if you like but it's not really necessary unless you're getting a bit of oil residue around the filter and want to keep it clean. Based on what? Quote
H_D Posted April 14, 2014 Posted April 14, 2014 No you don't need to change this. Keep the PCV valve if it's a daily driver as this will help the engine last longer and the filter can be left as it is or you could run a pipe to a catch can if you like but it's not really necessary unless you're getting a bit of oil residue around the filter and want to keep it clean. The pcv valve is a stupid restriction and i would advise everyone to remove theirs especially when running more power as it helps the engine breathe more efficiently when removed. Quote
RobSR Posted April 14, 2014 Posted April 14, 2014 I also cannot see how a PCV valve is going to make the engine last longer.. Quote
turbo Grant Posted April 14, 2014 Posted April 14, 2014 Pcv valve sucks in oil vapours adding cabon deposits over a long period of time Quote
Ryan_EP82 GT Posted April 20, 2014 Posted April 20, 2014 Can anyone else verify why it makes the engine last longer? AdamB will surely have something useful to say on the topic lol Quote
