_shaun_ Posted March 22, 2014 Posted March 22, 2014 Every one of us that browse rhd Japan and think of the best way to rob a bank. Quote
DRiiFTiE Posted March 22, 2014 Posted March 22, 2014 Has anyone seen this before ? how much is that in GB? Quote
Chops Posted March 22, 2014 Posted March 22, 2014 around 2200 quid. doesnt seem that expensive to me, they cost near on that to do custom lol Quote
akyakapotter Posted March 22, 2014 Posted March 22, 2014 £2125.96 + shipping + import tax ect would be mental money Quote
daniel_g Posted March 22, 2014 Posted March 22, 2014 how much is that in GB?Too fuckin much.£2125.96 + shipping + import tax ect would be mental moneyExactly. Imagine the customs release charges on that !! Quote
AdamB Posted March 22, 2014 Posted March 22, 2014 If you read the spec you get this as standard for your £2200 If you then want their forged pistons, rods cams , valve springs their all extra's on top of the £2200. From what it looks like the only thing they done is change the headgasket to something like 2mm-2.2mm and sold you an expensive engine that isn't even forged.Included:- Pistons and Piston Rings capable of 320PS- Resurfacing of the cylinder head and block- Crank and Con Rod Metal Bearings- Crankshaft resurfacing- Metal Head Gasket- Overhaul Gasket Kit- Port and Polish- Valve Alignment- Oil Element- NGK BKR6EY-11 Spark Plugs - See more at: http://www.rhdjapan.com/cruise-complete-zero-engine-5e.html#sthash.4wdF9Pp2.dpuf Quote
finbarh6 Posted March 22, 2014 Author Posted March 22, 2014 I was just looking through RHD looked interesting Quote
finbarh6 Posted March 22, 2014 Author Posted March 22, 2014 No if you read the little write up you get all that included !!If you read the spec you get this as standard for your £2200 If you then want their forged pistons, rods cams , valve springs their all extra's on top of the £2200. From what it looks like the only thing they done is change the headgasket to something like 2mm-2.2mm and sold you an expensive engine that isn't even forged.Included:- Pistons and Piston Rings capable of 320PS- Resurfacing of the cylinder head and block- Crank and Con Rod Metal Bearings- Crankshaft resurfacing- Metal Head Gasket- Overhaul Gasket Kit- Port and Polish- Valve Alignment- Oil Element- NGK BKR6EY-11 Spark Plugs - See more at: http://www.rhdjapan.com/cruise-complete-zero-engine-5e.html#sthash.4wdF9Pp2.dpuf Quote
maddox710 Posted March 22, 2014 Posted March 22, 2014 I tend not to go on rhd getting a semi over car parts isn't healthy Quote
