EP91Lover Posted March 22, 2014 Share Posted March 22, 2014 Ive got a project on the go. Putting a different engine into a Glanza. Im going to do the Abs delete and want to remove the power steering. What would be the best way to do it? Any way i can mod my steering rack that I've got or will i need to change it? Quote Link to post Share on other sites
morgey Posted March 22, 2014 Share Posted March 22, 2014 Loop the lines. Fit electric pump. Replace with an non p.s rack (may or may not need column) Quote Link to post Share on other sites
EP91Lover Posted March 22, 2014 Author Share Posted March 22, 2014 Cheers pal just looking for a non power steering rack now Quote Link to post Share on other sites
pockrockgtti Posted March 22, 2014 Share Posted March 22, 2014 Has anyone attempted to take the p/s rack apart and take out the seals to make it lighter to turn? Quote Link to post Share on other sites
rmsnoel Posted March 23, 2014 Share Posted March 23, 2014 Google it theres alot of stuff on this out there pluq morgey talked about this a while back. It would hardly matter on a turbo car though.. Quote Link to post Share on other sites
rob_bower Posted March 23, 2014 Share Posted March 23, 2014 (edited) Just to make you away the OP had been banned (again) as it was Sam mason trying to sneak back on after he was banned earlier this year. Edited March 23, 2014 by rob_bower Quote Link to post Share on other sites
Aamir Posted March 23, 2014 Share Posted March 23, 2014 Why not just remove the Power Steering fluid? Or the belt? So much easier lol Quote Link to post Share on other sites
Beastmode panda Posted March 24, 2014 Share Posted March 24, 2014 (edited) Why not just remove the Power Steering fluid? Really? Lol.. Edited March 24, 2014 by Rbz. Quote Link to post Share on other sites
TurboTobz Posted March 24, 2014 Share Posted March 24, 2014 Why not just remove the Power Steering fluid? Or the belt? So much easier lolgo try it, if you can deal with ut you'll look like a body builder in six months... lol Quote Link to post Share on other sites
Chand Posted May 11, 2014 Share Posted May 11, 2014 I'm in the process of doing this my self Removed all pipes to resevioir and to pump etc Removed pump brackets and belts Blanked off where the pipes fed up to the resevioir and the return from the pump with m16 bolts But that's where in struggling The other side where it goes hard pipes for the fluid to move to different sections of rack I've removed both pipes but I'm really struggling to find a bung to block off two of them but on two which stand up right on rack I need to fit a couple of gease nipples to pump gease into the rack This will help with non power steering Has anyone done this if so please help me I've tried everything 3/8 whit 12mm I've used imperial Just can not find a gease nipple or bung to suit the threads :/If anyone would help would be greatly appreciated Chand Quote Link to post Share on other sites
Beastmode panda Posted May 11, 2014 Share Posted May 11, 2014 I'm in the process of doing this my self Removed all pipes to resevioir and to pump etc Removed pump brackets and belts Blanked off where the pipes fed up to the resevioir and the return from the pump with m16 bolts But that's where in struggling The other side where it goes hard pipes for the fluid to move to different sections of rack I've removed both pipes but I'm really struggling to find a bung to block off two of them but on two which stand up right on rack I need to fit a couple of gease nipples to pump gease into the rack This will help with non power steering Has anyone done this if so please help me I've tried everything 3/8 whit 12mm I've used imperial Just can not find a gease nipple or bung to suit the threads :/ If anyone would help would be greatly appreciated Chand Chand, all I did was remove the whole lot, and cut down the 2 hard pipes that come out of the rack so they stick out about 2" or so and just loop it with a piece of braided hose. That's it.. Quote Link to post Share on other sites
Chand Posted May 11, 2014 Share Posted May 11, 2014 I've been advised by tuner to pump gease in How hard is it to turn etc? Quote Link to post Share on other sites
Beastmode panda Posted May 11, 2014 Share Posted May 11, 2014 I've been advised by tuner to pump gease in How hard is it to turn etc? Well fuck the tuner lol mines been fine for nearly 2 years now. The rack will still have fluid in it to keep it lubed up. It's fine, as soon as you're moving it's pretty much like normal mate. Quote Link to post Share on other sites
Chand Posted May 12, 2014 Share Posted May 12, 2014 Well fuck the tuner lol mines been fine for nearly 2 years now. The rack will still have fluid in it to keep it lubed up.It's fine, as soon as you're moving it's pretty much like normal mate.That's the best advise i get a lot lol fuck the tuner haha You got any pic of excatly what you've done You blank the holes which go to the res and the return from pump? Then the other side where hard pipes come from what did you do blank them of link them aswell ? Quote Link to post Share on other sites
Beastmode panda Posted May 12, 2014 Share Posted May 12, 2014 That's the best advise i get a lot lol fuck the tuner haha You got any pic of excatly what you've done You blank the holes which go to the res and the return from pump? Then the other side where hard pipes come from what did you do blank them of link them aswell ? Haven't blanked or blocked anything dude. Just strip the whole lot out til you get all the way to the sheering rack then you'll be left with 2 hard pipes, cut em down so they are eqal but stick out enough to get some braided hose and jibalee clips on. I'll take a picture for you as soon as I can mate. Quote Link to post Share on other sites
Chand Posted May 12, 2014 Share Posted May 12, 2014 You haven't blanked anything What about the pipes which aren't hard pipes mate the feed to reservoir and the return from the pump? Yeah if you could do get some pics that would be great mate Quote Link to post Share on other sites
asbo-v Posted May 12, 2014 Share Posted May 12, 2014 Just go to your local hose spares or pirtex to make one up but take your old connectors with done mine braided 15 pounds Quote Link to post Share on other sites
asbo-v Posted May 12, 2014 Share Posted May 12, 2014 Just go to your local hose spares or pirtex to make one up but take your old connectors with done mine braided 15 pounds Loop it hydro pipe or braided Hydro Quote Link to post Share on other sites
