kieran.liggins Posted April 9, 2014 Posted April 9, 2014 (edited) money waiting! Edited April 9, 2014 by kieran.liggins
kieran.liggins Posted April 9, 2014 Author Posted April 9, 2014 i want it too sound loud i have no clue about external wastegates-.-
daniel_g Posted April 9, 2014 Posted April 9, 2014 (edited) I have a silencer on my screamer / external wastegate so its a bit quieter because it was too loud... Edited April 9, 2014 by daniel_g
kieran.liggins Posted April 9, 2014 Author Posted April 9, 2014 what waste gate have you got mate?! i want a really loud one!
daniel_g Posted April 9, 2014 Posted April 9, 2014 I was only taking the piss man, are you maybe getting mixed up between dump valves and wastegates ?
kieran.liggins Posted April 9, 2014 Author Posted April 9, 2014 -.- thought my luck was in then hahaha! i just want my car sounding nice taking this shit japspeed exhaust off and going for a full 2.5inch with blitz back box just dont know what wastegate to buy?
_shaun_ Posted April 9, 2014 Posted April 9, 2014 A wastegate is what controls exhaust gasses to the turbo to control boost pressure. Once the desired boost pressure is reached it opens and allows exhaust gas to flow into the wastegate instead of the turbo. A dump valve is used to release the pressure when you back off the throttle. And most brands make a different noise. However if you don't run a bov at all the air escapes back though the turbo giving a chattering sound or "turbo flutter" which countless people seem to refer to as being made by the wastegate. Are you after a wastegate or a dump valve?
kieran.liggins Posted April 9, 2014 Author Posted April 9, 2014 yeahh basically going from internal to external but as this is my first external waste gate i have no clue about them-.- im running 1.4bar on internal wastegate, so what wastegate would i need to buy?
TrisK Posted April 9, 2014 Posted April 9, 2014 yeahh basically going from internal to external but as this is my first external waste gate i have no clue about them-.- im running 1.4bar on internal wastegate, so what wastegate would i need to buy?What turbo are you running? And what manifold? The external gate take off comes from the manifold?
kieran.liggins Posted April 9, 2014 Author Posted April 9, 2014 td04 internal but ive had the wastegate welded shut ready for my wepr ram s/s external with screamer yeahh
TrisK Posted April 9, 2014 Posted April 9, 2014 Ok. It's a wepr kit. So yo need a 38mm two bolt wastegate. Not a mvs vband one
kieran.liggins Posted April 9, 2014 Author Posted April 9, 2014 yeahh! bur whats the difference between like a tial and a cheap one?
daniel_g Posted April 9, 2014 Posted April 9, 2014 The quality of the item really. Cheap ones tend to have weaker diaphragms and the springs can sag meaning unstable boost. But i've never had any issues to date with cheap ones. Just use an EBC to set and control boost. But yeah all screamers are loud as fuck
triple j Posted April 9, 2014 Posted April 9, 2014 I love the rip of mine but kinda get use to it and will sound not as loud.
kieran.liggins Posted April 9, 2014 Author Posted April 9, 2014 so what shall i buy? im running a biltz boost controller setting 1 being 275 and setting 4 being 210 running 1.4bar then around 0.8 for 210so what psi spring shall i buy with the wastegate?
Azz Posted April 9, 2014 Posted April 9, 2014 so what shall i buy? im running a biltz boost controller setting 1 being 275 and setting 4 being 210 running 1.4bar then around 0.8 for 210so what psi spring shall i buy with the wastegate?Your forged I take it then buddy ? All wastages are pretty much the same sound but the tone can be altered slightly with a longer / shorter screamer pipe.Dump valves on the other hand everyone sounds different.I'd 'recommend tail or turbo smart, all the Wepr kits take the 38 mm 2 bolt type available from most places but I'd workz is usually the cheapest for a genuine one.By cheap by twice !
Chand Posted April 9, 2014 Posted April 9, 2014 As said I have a genuine tial 38mm two bolt for sale pm me if interested
kieran.liggins Posted April 9, 2014 Author Posted April 9, 2014 yeahh im fully forged on emange ultimate wanted to go with a td05 but as ive got a fully forged 1.3 there will be too much lag-.-i dont run a dump valve at the moment so i mite buy one yeah i bought a full kit from them direct worked out £70 cheaper than id workz i need a waste gate just dont want to rush into buying one then end up with the wrong one!but what spring would i have in the wastegate seeing as though im running 1.4bar?
daniel_g Posted April 9, 2014 Posted April 9, 2014 You need a spring that is the same or just below the minimum boost pressure youre gonna run. So if you sometimes run 0.8 bar then get a 0.8 spring or just below.
