Chops Posted May 3, 2014 Posted May 3, 2014 Got a problem here. i replaced pretty much all my suspension on the drivers side about 6 months ago, new wishbone, new balljoint, new shock, hub, the lot, added an anti lift kit too,while i was in there and now the damn thing pulls to the left. ive had it tracked several times, moved alloys about, and it still pulls to the left. banging my head on a wall here, anyone got any ideas? Quote
brendonware Posted May 4, 2014 Posted May 4, 2014 I just had this issue, put new suspension in and had it tracked after, was badly pulling to the right. Turns out one of my camber adjusters on my coilovers wasnt quite right (so one was on more of an angle) Brendon Quote
Chops Posted May 4, 2014 Author Posted May 4, 2014 i had all the tracking done and the tyres pressure, it does follow cambers with the anti lift kit but i dont think thats what it is. its doing my head in Quote
Amjad Posted May 4, 2014 Posted May 4, 2014 You have have staggered wheels, and one rear and one front both on the front axle? Quote
Chops Posted May 4, 2014 Author Posted May 4, 2014 i swapped the fronts round, then put the front nearside on the back. no difference Quote
daniel_g Posted May 4, 2014 Posted May 4, 2014 Is it violently pulling or just kinda drifting over ? Quote
Chops Posted May 4, 2014 Author Posted May 4, 2014 drifting. more when i accelerate. cant work it out. Quote
Cushion Posted May 4, 2014 Posted May 4, 2014 Sounds stupid but it aint a wheel bearing by any chance? Quote
Chops Posted May 4, 2014 Author Posted May 4, 2014 ofside got a spanking new one, and the nearsides fine too bud Quote
Cushion Posted May 4, 2014 Posted May 4, 2014 No worries, mine was pulling when it went, not much but noticeable Quote
Chops Posted May 5, 2014 Author Posted May 5, 2014 its not torque steer, its a constant pull to the left. Quote
don.binary Posted May 13, 2014 Posted May 13, 2014 I know this sounds quite silly, but could you have knocked a weight off your wheel when swapping?Happened to my mate once he had tracking done and everything only figured out problem when he had new tyres fitted and wheels balanced...Failing that I have no idea, everything else I can think of has already been mentioned Quote
Chops Posted May 13, 2014 Author Posted May 13, 2014 i swapped the alloys out completly for my rota gt3s, and it stopped instantly. same tyres, just replaced the alloys. the funny thing was that none of the original alloys had stayed in the same place while i was using them, so i cant see any reason why changing them all at once solved it. Quote
don.binary Posted May 13, 2014 Posted May 13, 2014 That's very strange indeed. Well I'm glad you were able to fix the problem Quote
Tmdep82mos Posted May 13, 2014 Posted May 13, 2014 Have you checked the wheel bearings mine pulls all over the place just checked the wheel bearing & 1 is ducked lol & slight play in my top mount on my d2s also both my steering threads have corroded so I'm changing the lot new track rod ends steering arms & new rose joint top mount bearing ill let you no once it's all done mate Quote
mccartney11 Posted May 13, 2014 Posted May 13, 2014 (edited) has your steering wheel ever been removed and put back on? possible it was misaligned and just makes it seem like you have to turn it to keep the car straight …..could be wrong but i thought my tracking was off and this was the problem, rotated the steering wheel round 2 notches and its perfect Edited May 13, 2014 by mccartney11 Quote
Turk Posted May 16, 2014 Posted May 16, 2014 Tyres give that problem. I had the same problem i put 2 new toyos on the front and sorted it out for me. Quote
Chops Posted May 16, 2014 Author Posted May 16, 2014 same tyres, same corners, different alloys, and it stopped immediately! Quote
