fremyjay Posted May 7, 2014 Posted May 7, 2014 Looking for a spec paddle clutch alignment tool, the plastic thing you get with your clutch, let me know if you have one
rwdrev Posted May 7, 2014 Posted May 7, 2014 i dont use anything, i either go by eye or, line the outside edge of the drive plate with the pressure plate, works every time.
Cushion Posted May 8, 2014 Posted May 8, 2014 I recently done mine and used a 15mm deep socket (15mm iirc, maybe 17mm) and it was near enough spot on
