Djaniero Posted May 12, 2014 Posted May 12, 2014 (edited) yO guys, I'm gonna have a stab at rotating my td04 later on this evening. I'm never done one before so a lil worried about damaging the fins. I'll be using this guide: http://www.toyotagtturbo.com/forums/showthread.php?11001-Steps-On-How-To-Rotate-A-Tdo4l-Turbo Has anyone got any better pics, or any other tips that may come in handy when doing this?Also are there any specialist tools that may come in useful? Thanks Edited May 12, 2014 by Djaniero Quote
akyakapotter Posted May 12, 2014 Posted May 12, 2014 Big circlip pliers and pliers to pull the locating pins out don't need to grind them off. Quote
Djaniero Posted May 12, 2014 Author Posted May 12, 2014 Thanks man. I don't have circlip pliers, but can borrow a set if need be. Quote
Socks Posted May 12, 2014 Posted May 12, 2014 Ull need oxy cet to get the core separated from the exhaust housing! Quote
akyakapotter Posted May 12, 2014 Posted May 12, 2014 (edited) Thanks man. I don't have circlip pliers, but can borrow a set if need be.Need big ones little ones won't touch it and lots of wd40 Edited May 12, 2014 by akyakapotter Quote
Djaniero Posted May 12, 2014 Author Posted May 12, 2014 Ull need oxy cet to get the core separated from the exhaust housing! Is that for step 3 in the above link? Need to big ones little ones won't touch it and lots of wd40 Ok cool. I'm onnit Quote
brendonware Posted May 16, 2014 Posted May 16, 2014 good luck! let me know how it goes! Brendon Quote
akyakapotter Posted May 16, 2014 Posted May 16, 2014 its easy to do it you have the tools. I soaked mine in wd40 for a good 3days before i even tried to rotate Quote
brendonware Posted May 18, 2014 Posted May 18, 2014 Looks like i'll be having a go at this very soon as i just bought a td04 that needs rotating! One thing that i dont get is that the oil return seemingly will be in the wrong place and how would you get the actuator to line up? cus its going to be miles out! Brendon Quote
Kyle_R Posted May 18, 2014 Posted May 18, 2014 Looks like i'll be having a go at this very soon as i just bought a td04 that needs rotating! One thing that i dont get is that the oil return seemingly will be in the wrong place and how would you get the actuator to line up? cus its going to be miles out! Brendonweld the wastegate inside the turbo and go external that's what I'm currently doing ATM while I wait for my engine to get back Quote
Djaniero Posted May 18, 2014 Author Posted May 18, 2014 I was gonna use this guide RBZ made, but luckily I managed to get a setup with an external wastegate. HTH http://www.ukstarletowners.com/topic/62968-how-to-make-an-actuator-work-on-a-rotated-td04/ Quote
brendonware Posted May 29, 2014 Posted May 29, 2014 just rotated my turbo and to be honest it was pretty easy, just have a problem with the top water pipe as now its rotated its hitting the manifold flange so dont really know what to do whether to bend it or what lol Brendon Quote
Liam_D Posted May 29, 2014 Posted May 29, 2014 just rotated my turbo and to be honest it was pretty easy, just have a problem with the top water pipe as now its rotated its hitting the manifold flange so dont really know what to do whether to bend it or what lol BrendonHave you rotated the whole core assembley too? As that should stay in the same position and you just move the turbine and compressor housings Quote
brendonware Posted May 30, 2014 Posted May 30, 2014 Yeah rotated both sides, it's all on the car now Brendon Quote
