stewwy_94 Posted May 12, 2014 Share Posted May 12, 2014 In the morning my 98 starlet wont start. There's no fuel getting past the injectors but later in the morning it will start and idle fine can anyone help? Quote Link to post Share on other sites
MARC MOSS Posted May 12, 2014 Share Posted May 12, 2014 Weird ... Cold mornings or just mornings in general? Quote Link to post Share on other sites
MARC MOSS Posted May 12, 2014 Share Posted May 12, 2014 Maybe you need to set the clock forward a few hours and fool the lazy bastard out of its sleep lol Quote Link to post Share on other sites
Jamie5414 Posted May 12, 2014 Share Posted May 12, 2014 change the clock inside it will trick itLOL amazing Quote Link to post Share on other sites
Kyle_R Posted May 12, 2014 Share Posted May 12, 2014 On 5/12/2014 at 5:49 PM, MARC MOSS said: Maybe you need to set the clock forward a few hours and fool the lazy bastard out of its sleep lolbest thing I've read today pmsl Quote Link to post Share on other sites
TurboTobz Posted May 12, 2014 Share Posted May 12, 2014 FurKingLol Quote Link to post Share on other sites
stewwy_94 Posted May 12, 2014 Author Share Posted May 12, 2014 IM being serious as soon as the suns been on it it fires up first turn Quote Link to post Share on other sites
MARC MOSS Posted May 12, 2014 Share Posted May 12, 2014 Hmmm maybe a blanket over the bonnet so it doesn't get cold?Na lol sorry in all serious maybe a sensor is faulty, probs to do with cold start.. Have you done an ecu fault code check? Quote Link to post Share on other sites
stewwy_94 Posted May 12, 2014 Author Share Posted May 12, 2014 Ive changed the temp sensors and i haven't yet will have to get it done Quote Link to post Share on other sites
TurboTobz Posted May 12, 2014 Share Posted May 12, 2014 Have you changed the coolant temp sensor? Quote Link to post Share on other sites
richardc9052 Posted May 12, 2014 Share Posted May 12, 2014 Have you tried changing the pump? Quote Link to post Share on other sites
stewwy_94 Posted May 13, 2014 Author Share Posted May 13, 2014 Its got a new pump and i have changed both temp sensors Quote Link to post Share on other sites
stewwy_94 Posted May 13, 2014 Author Share Posted May 13, 2014 Could it be a fault with the ecu?? Quote Link to post Share on other sites
scutch0 Posted May 24, 2014 Share Posted May 24, 2014 Is the fuel pump working ok? I've had an issue recently where it did the same, turned out to be the fuel pump. Quote Link to post Share on other sites
stewwy_94 Posted May 24, 2014 Author Share Posted May 24, 2014 The fuel pump is fine just put a new one in and changed the ecu and still don't start in the mornings Quote Link to post Share on other sites
Gainzy Posted May 25, 2014 Share Posted May 25, 2014 Must be something basic, give the plugs a good brush up, a diagnostic test may help as above.. Quote Link to post Share on other sites
mech5107 Posted May 25, 2014 Share Posted May 25, 2014 Is the pump relay clicking in the morning tries? Quote Link to post Share on other sites
stewwy_94 Posted May 27, 2014 Author Share Posted May 27, 2014 It all works as it should just don't start because the injectors don't open Quote Link to post Share on other sites
