Picked up this this little beast yesterday non runner and about rough
Today it starts and drives although the clutch is ruined lol
Couple of picks of the Mr
tbh its a bit overkill, its a full kit, flywheel etc if you're interested hit me up but it will be a lot more than a oem replacement lol
you might find that has the smaller 200mm clutch being a F reg. i might have a 212mm stock flywheel here though, ill have to have a measure, if i do that opens your options for clutch plates as any from glanza, 20v, new celica and corolla t sports all fit. will need the pressure plate to suit though,
My spare is from a 200mm think it's been lightened a bit but nothing special.
You could get a 212mm flywheel from any non tvis 16v 4age and any 20v. I think 7afe's from 1.8 carinas etc had 212mm but would need to make sure it was a 8 bolt flywheel.
Any questions fire away ill help if I can :)
Get the clutch sorted and start beating on it. Get the 4age bug ;)
A yank local to me had one of these and he made a ram air scoop for it. Made a huge improvement lol was quicker than a lightly modded glanza
just been looking at blyton park for june funnily enough
to be honest the body isn't that clean but its not that bad under side seams solid but will update in good time ( tomorrow once its on the ramp)
Clutch is in and spot on, had a drive of this today kept changing gear early once I'd found how high it revs loved it even if cruising in 5th foot down and it pulls very cool car
Few pics from the job and some of the underside
