wezy Posted May 13, 2014 Share Posted May 13, 2014 Are glanza and gt front oem braces the same and will a turbo strut brace fit a N/A?? Thanks! Quote Link to post Share on other sites
LukeSR Posted May 13, 2014 Share Posted May 13, 2014 Yeah there both the same and will fit. Quote Link to post Share on other sites
morgey Posted May 13, 2014 Share Posted May 13, 2014 You will need to bend the fuel filter out the way iirc Quote Link to post Share on other sites
wezy Posted May 13, 2014 Author Share Posted May 13, 2014 Right, gave a man a glanza strut brace and he tells me it wont fit his glanza! his only has 3 bolts on the strut tower, I thought most glanza's had 4? would it make a difference? Quote Link to post Share on other sites
hookie663 Posted May 13, 2014 Share Posted May 13, 2014 Yes mate Quote Link to post Share on other sites
wezy Posted May 13, 2014 Author Share Posted May 13, 2014 You will need to bend the fuel filter out the way iirc yep, cheers, done that but the problem i'm hveing here is the holes wont line up with the bolts! Quote Link to post Share on other sites
morgey Posted May 13, 2014 Share Posted May 13, 2014 Stock they have 3 but the hole for the 4th is there. When you fit coilovers they utilise the 4th hole. Car you get pictures of the problem? Quote Link to post Share on other sites
Gainzy Posted May 13, 2014 Share Posted May 13, 2014 Just needs abit of a bang on..use the force! Quote Link to post Share on other sites
Gainzy Posted May 13, 2014 Share Posted May 13, 2014 (edited) Lift the other side up half way it will take abit boshing on Edited May 13, 2014 by Gainzy Quote Link to post Share on other sites
wezy Posted May 13, 2014 Author Share Posted May 13, 2014 not me doing it, gave it to a lad as a swap Quote Link to post Share on other sites
Gainzy Posted May 13, 2014 Share Posted May 13, 2014 not me doing it, gave it to a lad as a swapLol just sit back and wack the kettle on Quote Link to post Share on other sites
StarletSr? Posted May 13, 2014 Share Posted May 13, 2014 Should he be working on his own car if he cant fit a strut brace? Quote Link to post Share on other sites
Dean_mc88 Posted May 13, 2014 Share Posted May 13, 2014 Should he be working on his own car if he cant fit a strut brace?Hahaha true !! Quote Link to post Share on other sites
wezy Posted May 13, 2014 Author Share Posted May 13, 2014 Ah don't talk to me haha, but when he wont hold up his end of the swap till this is sorted i'm in trouble! Quote Link to post Share on other sites
kavan-k Posted May 14, 2014 Share Posted May 14, 2014 Is the strut upside down? He sounds like a dummy that might do that haha Quote Link to post Share on other sites
loguey Posted May 14, 2014 Share Posted May 14, 2014 Does he know how a strut brace works or just thinks it looks pretty? Quote Link to post Share on other sites
