Chops Posted May 24, 2014 Posted May 24, 2014 Hey all, started a new thread cause the problems with my cars electrics seem to go on and on lol. I just managed to change my alternator out after it being sat for week, and now it wont start. when i put my jump pack on it it cranks a little bit then dies, theres no stuttering of life at all. interestingly, when i set the ignition barrel to on the temp gauge goes mad, way off the end of the end to its maximum point, and the engine light comes on. no idea what im doing with electronics really, i was hoping someone on here might be able to help with this! Quote
Gainzy Posted May 24, 2014 Posted May 24, 2014 Sounds like battery to me, get a lend of a battery check your earth and negative wires to clean metal Quote
Chops Posted May 25, 2014 Author Posted May 25, 2014 Chucked a new battery in today, still wont start. the temp gauge thing has moved over to the boost pressure gauge, that now maxes out when i turn the ignition to on. dismantled the dizzy to inspect cause its quite worn but my phone died so i couldnt take a pic to show on here. anyone got a pic of a knackered rotor arm/dizzy cap for me to see and compare it? would be a massive help. also couldnt get any arcing when i pulled one of the ht leads off of the dizzy and cranked it over, but i dont think its the king lead cause i just put that in. helllp! Quote
Whitenoize Posted May 25, 2014 Posted May 25, 2014 Chucked a new battery in today, still wont start. the temp gauge thing has moved over to the boost pressure gauge, that now maxes out when i turn the ignition to on. dismantled the dizzy to inspect cause its quite worn but my phone died so i couldnt take a pic to show on here. anyone got a pic of a knackered rotor arm/dizzy cap for me to see and compare it? would be a massive help. also couldnt get any arcing when i pulled one of the ht leads off of the dizzy and cranked it over, but i dont think its the king lead cause i just put that in. helllp!You are having no luck at all with your car these days dude Quote
Chops Posted May 25, 2014 Author Posted May 25, 2014 No lol, none at all. I checked it all over like mad the day before japfest, up untill silly oclock making sure everything i could check was good to go. woke up late and missed the convoy as an ironic result, and broke everything booming flatout down the motorway in the rain playing catchup lol. massive fml times for me. my 'new' impreza is pretty dead at the moment too, stutters n overheats like mad. Quote
Chops Posted May 26, 2014 Author Posted May 26, 2014 Could this be my igniter, or whatever its called bolted to the firewall? Quote
5T4R7ET N/A Posted May 26, 2014 Posted May 26, 2014 yes, it has a black bracket that has to be earthed. you wont get spark if its not earthed. Quote
Chops Posted May 26, 2014 Author Posted May 26, 2014 (edited) Are they known to fail? Edited May 26, 2014 by Chops Quote
mikey4410 Posted May 26, 2014 Posted May 26, 2014 Ahh man I cant believe u havent got up and goin man, I am myself having trouble electronics atm. Quote
Chops Posted May 26, 2014 Author Posted May 26, 2014 Yer i noticed the fpr problem, its a shame i cant offer any help, i hate dealing with electronics so much lol, they can look all fine n dandy but not work at all. bodywork or mechanical stuff no problem, im all over it, but not electronics, fuk dat :L Quote
Chops Posted May 28, 2014 Author Posted May 28, 2014 Fixed! turns out the king lead was dead, and then the injectors or whatever is earthed to the intake mani wasn't bolted back on when i replaced the sensor on the end. the king leads tempory replacement is a bit ghetto, made it outta some cable im gonna use at some point so its about 3 meters long and is coiled all over the bay lol. Quote
mikey4410 Posted May 28, 2014 Posted May 28, 2014 Yay !!!! Veey well done matey, well chuffed for you.think I have found me problem also, think it was afr giving dud reading.dam thing Quote
Chops Posted May 28, 2014 Author Posted May 28, 2014 damn, afrs arnt cheap! if ifound mine wasnt even accurate id be furious, can you replace the sensor on it or something? Quote
mikey4410 Posted May 28, 2014 Posted May 28, 2014 Yeap I can replace sensor for around 70 quid plus but its not something I can afford for a good while.I know me afrs are fine and safe anywho, but still its a pain giving dud readings as I have been on a wild goose chase tbh.what ure running voltage now mate ?? Quote
Chops Posted May 28, 2014 Author Posted May 28, 2014 sits on around 14/14.2. the ghetto king lead makes it all feel a bit funny, engine note sounds different and it hesitates on boost so i didnt push it, just limped home. the new alternator whines a bit too, sounds alot like a supercharger lol. Quote
mikey4410 Posted May 28, 2014 Posted May 28, 2014 Thats superb voltage.good stuff.ohh dear,yeah best get a new lead asap.dont want any damage happening internally do you.the alternator might have the belt to tight or sumin as it was in good order when used last for sure.hope u come to the next meet dude !!!! Quote
Chops Posted May 28, 2014 Author Posted May 28, 2014 definitely, gotta get my lightened flywheel, clutch, second speaker door card, afr and mines ecu in before then, much to do lols. Quote
