ForgedCraigo93 Posted June 26, 2014 Posted June 26, 2014 http://m.gumtree.com/p/toyota/1996-toyota-starlet-glanza-v-1.3-turbo-moonstone-silver./1070736229Bloke says smoke at lights sometimes. When you rev it it smokes?Smells of oil? Basically is it worth buying? Thanks for any advice. Quote
russ78 Posted June 26, 2014 Posted June 26, 2014 could be turbo seals , might be worth while compression testing engine before you buy Quote
ForgedCraigo93 Posted June 26, 2014 Author Posted June 26, 2014 If it is turbo seals how much would it be roughly to sort it? Quote
russ78 Posted June 26, 2014 Posted June 26, 2014 either new turbo or turbo rebuild mate anything from 50quid to 250quid depending if you have it rebuilt or swap it for a secobdhand unit.thats if it is that, could also be valve stem seals, cracked ringlands etc etc but a compression test should give u a good idea Quote
ForgedCraigo93 Posted June 26, 2014 Author Posted June 26, 2014 Don't want to sound thick but how do you do a compression test? Quote
russ78 Posted June 26, 2014 Posted June 26, 2014 search compression test on youtube watch a couple of videos very easy to do Quote
ForgedCraigo93 Posted June 26, 2014 Author Posted June 26, 2014 Surely you can't do that when just going to view a car :/? Quote
mikey4410 Posted June 26, 2014 Posted June 26, 2014 I wouldnt purchase a starlet unless I could undertake a compression check, IT IS IMPERATIVE. I did on my donor car I brought, the guy was fine with it as I know my stuff. Quote
Eynonz Posted June 26, 2014 Posted June 26, 2014 (edited) You should avoid the car if they refuse to let you do one. Edited June 26, 2014 by Eynonz Quote
ForgedCraigo93 Posted June 26, 2014 Author Posted June 26, 2014 Wish I knew my stuff a bit more lol Quote
mikey4410 Posted June 26, 2014 Posted June 26, 2014 Totally agree with eynonz.You could buy a complete lemon otherwise Quote
Eynonz Posted June 26, 2014 Posted June 26, 2014 (edited) Wish I knew my stuff a bit more lol You'll learn over time don't worry. I'm still a complete nugget when it comes to these cars, most of the enjoyment is the learning of new things. Edited June 26, 2014 by Eynonz Quote
ForgedCraigo93 Posted June 26, 2014 Author Posted June 26, 2014 Don't think he would mind. It's just I don't have any gear to do one or the right knowledge. Just spoke to him n he said it it only really when you rev like put your foot down real quick, and the smoke isn't thick. He did sound like a bit of a lemon. He said he just wants it sold as his got his new car now. Quote
Idrees Posted June 26, 2014 Posted June 26, 2014 I wouldnt purchase a starlet unless I could undertake a compression check, IT IS IMPERATIVE. I did on my donor car I brought, the guy was fine with it as I know my stuff.What happens if you break something while doing it? For example your compression tester snaps in the engine? I've seen it happen before so I wouldn't let any random person carry out a compression test on my car if I was selling it, unless I had the money in my hand of course.Also, this is vri's car so you might want to search his past sales posts before taking time out to view Quote
mikey4410 Posted June 26, 2014 Posted June 26, 2014 I do get what you mean iddy, do see that could create problems.I woukd in that case have to see the test performed infront of me.I even tested my n/a before I bought it, the thing you have to bear in mind is starlet ringlands are so prone to breaking and and are made of soft cheese so the likely hood of buying a engine with an issue is definatley a real one. Quote
Gainzy Posted June 26, 2014 Posted June 26, 2014 Surely you can't do that when just going to view a car :/?If you have 2k in your pocket or whatever you want to try and not waste a penny, just ask before hand if any inspection is welcome. Quote
fremyjay Posted June 27, 2014 Posted June 27, 2014 (edited) The guy is dodgy as they come, him and his mate have been banned from here for selling dodgy motors, i also see he's refrained from taking photos in front of the usual gates Edited June 27, 2014 by fremyjay Quote
