scottieboi94 Posted July 2, 2014 Share Posted July 2, 2014 (edited) I have just bought a civic rad and the pipes coming of the rad are much larger than a standard rad, i struggled to get the coolant pipes on but managed to in the end but couldn't use the hose clips so had to use jubilee clips, anyone else had this problem? The curvature of the pipe also isn't correct due to the rad pipe being in a different place the a standard rad aswell, does this affect anything? Edited July 2, 2014 by scottieboi94 Quote Link to post Share on other sites
akyakapotter Posted July 2, 2014 Share Posted July 2, 2014 Nope will be fine mine is like that I used oem pipe aswell Quote Link to post Share on other sites
_shaun_ Posted July 2, 2014 Share Posted July 2, 2014 As above its fine there isn't much difference Quote Link to post Share on other sites
steve1093 Posted July 2, 2014 Share Posted July 2, 2014 Fitted mine last week, did exactly the same... it'll be fine Quote Link to post Share on other sites
aidanep71 Posted July 2, 2014 Share Posted July 2, 2014 Shorten the hose a bit where it goes on the the engine and rad a small bit and it will fit better Quote Link to post Share on other sites
scottieboi94 Posted July 2, 2014 Author Share Posted July 2, 2014 Shorten the hose a bit where it goes on the the engine and rad a small bit and it will fit better Don't really wanna start cutting up samco hoses tbh mate im sure you understand haha Quote Link to post Share on other sites
scottieboi94 Posted July 2, 2014 Author Share Posted July 2, 2014 I was looking at a triple core rad from tuning developments, do they custom make the rads to fit a glanza e.g. smaller pipes etc or are they the same as what i have now? Quote Link to post Share on other sites
_shaun_ Posted July 3, 2014 Share Posted July 3, 2014 They will just be the same the difference in size is tiny so not worth making a totaly new rad Quote Link to post Share on other sites
aidanep71 Posted July 3, 2014 Share Posted July 3, 2014 Look how close it is to the manifold because of the kink.. you will only need to shorten it 10mm or so each end so you will still have the writing on the hose if that's what's worrying ya Quote Link to post Share on other sites
daniel_g Posted July 3, 2014 Share Posted July 3, 2014 Ive had this before aswell. The silicon hoses can be a bit tight to get on and the OEM clips are too small.Youd better heatwrap that mani or wrap something round that top hose because it'll burn through in no time. Or take it off and turn it round the other way, this gave me a bit more clearance if you dont wanna chop it down. Quote Link to post Share on other sites
scottieboi94 Posted July 3, 2014 Author Share Posted July 3, 2014 It will burn through the hose if it isn't touching it? Quote Link to post Share on other sites
Mk3 silver gt Posted July 3, 2014 Share Posted July 3, 2014 I had the same problem but I managed to get the coolant pipes pushed right on I used fairy liquid and they slid on so easy, but I was there for a good half hour before I thought to use fair liquid Quote Link to post Share on other sites
scottieboi94 Posted July 3, 2014 Author Share Posted July 3, 2014 I had the same problem but I managed to get the coolant pipes pushed right on I used fairy liquid and they slid on so easy, but I was there for a good half hour before I thought to use fair liquid Might try it Quote Link to post Share on other sites
daniel_g Posted July 3, 2014 Share Posted July 3, 2014 It will burn through the hose if it isn't touching it?Maybe not but not worth the risk imo ive seen manis glow red. Quote Link to post Share on other sites
scottieboi94 Posted July 3, 2014 Author Share Posted July 3, 2014 Maybe not but not worth the risk imo ive seen manis glow red. Ill have a play with it mate Quote Link to post Share on other sites
