24smiley24 Posted August 20, 2014 Posted August 20, 2014 Hi all got a problem with my glanza been told it's a few different things main one being o rings gone... But there is no knocking ect car is still geting me to work and back round about 50miles a day. But I am scared to go in to boost incase oil gose every where again!! Any advice would be great-full it's running these mods if it helps.....Subaru td04 turbo Ram air air filterToyo manifold and de-cat2.5 japspeed cat back exhaustfront mount intercoolerhks dump valve oil catch canjam racing ecu costwalbro 255 fuel pump15" red rota wheelslowered on tein springs Subaru front seatsfront strut bracerear 3 point barc-pillar barapexi turbo timergreddy boost controller Quote
daniel_g Posted August 20, 2014 Posted August 20, 2014 Piston ring or ringland failure most likely. Quote
24smiley24 Posted August 20, 2014 Author Posted August 20, 2014 Ideas on how long it's going to hold up? Quote
russ78 Posted August 20, 2014 Posted August 20, 2014 depends how bad it is... compression test the engine it will give you some level of severity Quote
daniel_g Posted August 20, 2014 Posted August 20, 2014 I wouldn't count on it being very long. I'd get it sorted asap. If youre lucky it'll be ring failure, but most likely the actual ringlands on the pistons will be cracked / breaking away. Quote
mikey4410 Posted August 20, 2014 Posted August 20, 2014 It wont last.its failed, end of.that starlet needs tearing down and rebuilding before any more damage occurs.without doubt u have melted piston or ringlands have broken up. Quote
24smiley24 Posted August 20, 2014 Author Posted August 20, 2014 Thanks for the reply guys...If it is just ring failure is that a easy job or amI basically still f##ked Quote
patman Posted August 20, 2014 Posted August 20, 2014 Still fooked mate as you still need to strip the engine Quote
daniel_g Posted August 20, 2014 Posted August 20, 2014 If its just the rings then that means you can save your pistons. But yeah its still a big job unfortunately.Noticed you live in Prestwick, good place to take it would be G.I in Killie. Quote
24smiley24 Posted August 20, 2014 Author Posted August 20, 2014 Yeah was on the phone to them today there fully booked till Tuesday just hope it holds up till then as it's my daily car... Been told if am going to fix it would be better doing the forged rote but again it's money and time.... With the mods a have what else would a need to do this?? Quote
Gainzy Posted August 21, 2014 Posted August 21, 2014 sell the ecu to buy a cheap ruabout, use that for 8-10 weeks till it's forged sell the runabout to fund for the upgraded management either that or break it for parts cash is king unfortunatley! You could always buy another engine and transfer parts aswell but how much can you trust 2nd hand engine. Quote
24smiley24 Posted August 21, 2014 Author Posted August 21, 2014 Right guys got a compression test from 1 was 175 from 2 was 155 from 3 was 105 and from 4 was 175 so will this just require new pistons? Or should just strip the full car?? Quote
