Hello,
I want to buy a Forged 5efte.
Setup:
JE Piston set
5efhe conrods
Stock headgasket and bolts + toyota bearings
I have a td04l turbo.
How many hp can i have on this block? And what is the max boost with the td04l? 1,5 bar??
I have 360cc injectors. Is this good or do i need 440cc injectors?
Stephan from Holland
Edited by stephan777
You should see well in excess of 285hp but it depends on your tune and your engine setup, why don't you go for some scat rods?
max boost people run is 1.4 bar on a td04L, you will need bigger injectors also then the 360s you have at the moment.
440s would be a much better choice or just to give you that little bit extra get some 460s with you going 5E.
what management you planning to run?
Because the 5efhe rods are very strong.
I have a greddy emange blue. And i have a fuel pressure regulator to.
fair enough,
emanage blue will run the 460s but will run a little rich on idle because the blue can't back the injectors off.
285hp is good enough.
Is 300hp possible with a td04l?
Setup:
5Efte forged motor
JE Piston set
5efhe conrods
Zisco performance ramhorn
Zisco performance Downpipe
Td04L turbo
HKS External Wastegate
HKS Blow off valve
Sard fuel pressure regulator
Go fast bits boostcontroller
Greddy emanage blue Piggyback
Tanabee exhaust system
HKS Mushroom airfilter
Spec one 6 puck paddle clutch
360cc Injectors
255 l/ph fuel pomp
JAM ECU
Jperformance Front Mount Intercooler
If you run a higher compression on the 5E i reckon you could possibly achieve 300 or near on a TD04 @ 1.4 bar.
Infact maybe that would be too much boost (depending on the C.R) would just be a case of turning up the boost until knock was detected and then wind it down a bit.
Edited by daniel_g
stefan is J,E not floating pin ?????? dont tink it will fit oem rod ????
This is a very good point and needs to be considered, i personally don't know but can find out.
Throw a set of 4efte pistons and a good head gasket on one and it will take a td05 at 1.2 bar with a good tune
i did that exact setup with my mines and sard fpr :) bit rich down low but spot on at the top end
personally i think the tdo4 is to small on a 5e it will drop of like a ct9 ( but not that bad !! ) on a 5e thats why i said tdo5 :) :)
