stephan777 Posted August 26, 2014 Share Posted August 26, 2014 (edited) Hello, I want to buy a Forged 5efte. Setup: JE Piston set5efhe conrodsStock headgasket and bolts + toyota bearings I have a td04l turbo. How many hp can i have on this block? And what is the max boost with the td04l? 1,5 bar?? I have 360cc injectors. Is this good or do i need 440cc injectors? Stephan from Holland Edited August 26, 2014 by stephan777 Quote Link to post Share on other sites
Gilly Posted August 26, 2014 Share Posted August 26, 2014 You should see well in excess of 285hp but it depends on your tune and your engine setup, why don't you go for some scat rods? max boost people run is 1.4 bar on a td04L, you will need bigger injectors also then the 360s you have at the moment. 440s would be a much better choice or just to give you that little bit extra get some 460s with you going 5E. what management you planning to run? Quote Link to post Share on other sites
stephan777 Posted August 26, 2014 Author Share Posted August 26, 2014 Because the 5efhe rods are very strong. I have a greddy emange blue. And i have a fuel pressure regulator to. Quote Link to post Share on other sites
Gilly Posted August 26, 2014 Share Posted August 26, 2014 On 8/26/2014 at 9:57 PM, stephan777 said: Because the 5efhe rods are very strong. I have a greddy emange blue. And i have a fuel pressure regulator to. fair enough, emanage blue will run the 460s but will run a little rich on idle because the blue can't back the injectors off. Quote Link to post Share on other sites
5e colin Posted August 27, 2014 Share Posted August 27, 2014 stefan is J,E not floating pin ?????? dont tink it will fit oem rod ???? i would dump the tdo4 and go tdo5 Quote Link to post Share on other sites
Cherry Posted August 27, 2014 Share Posted August 27, 2014 Bin the td05 and go gt28 Quote Link to post Share on other sites
richardc9052 Posted August 27, 2014 Share Posted August 27, 2014 Bin them all, use an m62 supercharger and an rx60 bb turbo Quote Link to post Share on other sites
stephan777 Posted August 27, 2014 Author Share Posted August 27, 2014 td04 is good enough Quote Link to post Share on other sites
_shaun_ Posted August 27, 2014 Share Posted August 27, 2014 I've got a set of 460ccs in my breakers thread if u need them Quote Link to post Share on other sites
stephan777 Posted August 27, 2014 Author Share Posted August 27, 2014 285hp is good enough. Is 300hp possible with a td04l? Setup: 5Efte forged motor JE Piston set5efhe conrodsStock headgasket and bolts + toyota bearingsZisco performance ramhornZisco performance DownpipeTd04L turboHKS External WastegateHKS Blow off valveSard fuel pressure regulatorGo fast bits boostcontrollerGreddy emanage blue PiggybackTanabee exhaust systemHKS Mushroom airfilterSpec one 6 puck paddle clutch360cc Injectors255 l/ph fuel pompJAM ECUJperformance Front Mount Intercooler Quote Link to post Share on other sites
daniel_g Posted August 27, 2014 Share Posted August 27, 2014 (edited) If you run a higher compression on the 5E i reckon you could possibly achieve 300 or near on a TD04 @ 1.4 bar.Infact maybe that would be too much boost (depending on the C.R) would just be a case of turning up the boost until knock was detected and then wind it down a bit. Edited August 27, 2014 by daniel_g Quote Link to post Share on other sites
amatthews45 Posted August 27, 2014 Share Posted August 27, 2014 Wow! I thought the 5efte engine needed more stuff than just pistons to be forged. Sounds like a ideal cheap way for more boost to me Quote Link to post Share on other sites
richardc9052 Posted August 27, 2014 Share Posted August 27, 2014 Throw a set of 4efte pistons and a good head gasket on one and it will take a td05 at 1.2 bar with a good tune Quote Link to post Share on other sites
Gilly Posted August 27, 2014 Share Posted August 27, 2014 On 8/27/2014 at 8:37 AM, 5e colin said: stefan is J,E not floating pin ?????? dont tink it will fit oem rod ???? This is a very good point and needs to be considered, i personally don't know but can find out. Quote Link to post Share on other sites
amatthews45 Posted August 27, 2014 Share Posted August 27, 2014 How easy is it to find one of these blocks with the thicker rods? They pricey? Because my dead 4efte has pistons. That means all I need is a good headgasket kit Quote Link to post Share on other sites
richardc9052 Posted August 27, 2014 Share Posted August 27, 2014 I have one needing crank re ground, not for sale and that's how most of the 5e's out there sit, hidden, waiting to be built Quote Link to post Share on other sites
5e colin Posted August 27, 2014 Share Posted August 27, 2014 On 8/27/2014 at 8:17 PM, richardc9052 said: Throw a set of 4efte pistons and a good head gasket on one and it will take a td05 at 1.2 bar with a good tune i did that exact setup with my mines and sard fpr bit rich down low but spot on at the top end personally i think the tdo4 is to small on a 5e it will drop of like a ct9 ( but not that bad !! ) on a 5e thats why i said tdo5 :) Quote Link to post Share on other sites
amatthews45 Posted August 28, 2014 Share Posted August 28, 2014 So how much is a 5e? The good one with thicker rods? Quote Link to post Share on other sites
richardc9052 Posted August 28, 2014 Share Posted August 28, 2014 Your looking at spending the same as buying a good 4efte really Quote Link to post Share on other sites
amatthews45 Posted August 28, 2014 Share Posted August 28, 2014 About 500 then? Quote Link to post Share on other sites
