turbominicooper Posted September 23, 2014 Posted September 23, 2014 I am at the phase of the suspension, handling and braking of my car. at current I have:15x7 rimsfull set of ohlins suspension (rebuilt) with having a strong mini background I like my cars to handle like its on tracks, also I live on a small island where windy and narrow roads are the majority (we have 1 A road which is 4 miles long). I kind of know what im doing form a braking point of view - drilled and grooved discs with green stuff pads but I really need advice on the handling as whats best to do for a solid, heavy cornering suspension setup? I want it to handle like this - https://www.youtube.com/watch?v=CiONW1ULqzc Quote
Socks Posted September 23, 2014 Posted September 23, 2014 Best Mods you can do to a starlet to gain improved handling: LSD fitted into Gearbox Rear Anti-Roll Bar Front Lower Arm Bar Brace Coilover Suspension Kit Quote
turbominicooper Posted September 23, 2014 Author Posted September 23, 2014 [sigh] another grand ;) cheers Socks, ive got coil overs so will aim for the brace and arb, work upto the diff I think. what about poly mounts etc? Quote
Socks Posted September 23, 2014 Posted September 23, 2014 Cant say poly engine mounts will do much for handling. But they will stop engine slop coming on and off load and sharpen the gear changes up... Quote
daniel_g Posted September 23, 2014 Posted September 23, 2014 Advise changing ball joints and trackrod ends if they are a bit old and worn, its like night and day afterwards Also what tyres you running ? Quote
turbominicooper Posted September 23, 2014 Author Posted September 23, 2014 nothing special on the tyres just set of nexen blues. will upgrade tyres when I change rims out Quote
morgey Posted September 23, 2014 Posted September 23, 2014 Few of my mates have changed to poly wishbone mounts and have found the car is much more susceptible to follow tyre tracks and whitelines so if the roads are a bit pish best not bother. But if theyre old a new set might be advisable.That said, i would add to socks list a anti lift kit. They replace the rear mount on the front wishbones (poly) they make the steering more positive i found. But best buy is deffo the Lsd but obviously the most work and most expensive. Quote
AdamB Posted September 23, 2014 Posted September 23, 2014 Tyres, LSD , Ant roll bars in that order imo. Providing all your rubber mounts are good. Poly engine mounts are a good upgrade as they help to reduce wheel hop. Having designed a few suspension and chassis systems for race cars I would find out what specs your ohlins are, the spring rate, the rate of bump and droop. This is one area where everyone gets it wrong. Quote
Amjad Posted September 24, 2014 Posted September 24, 2014 Tyres, RARB, ALK, polybushes, braces, LSD (I put it last because it's pretty expensive compared to the rest of what I've mentioned) Quote
Chops Posted September 24, 2014 Posted September 24, 2014 (edited) i rock an rsr adjustable panhard, rsr lowering springs, oem rear brace and a whiteline anti lift kit and find its super responsive without the crashy speedhump skuffing nature of cars with coilovers on bullshit british roads. id consider a more road friendly set up and add parts till your happy bud. Edited September 24, 2014 by Chops Quote
Turk Posted September 27, 2014 Posted September 27, 2014 Even just your geometry setup properly makes a huge difference. Stuff like camber, caster and toe. I found a bit of negative toe gives huge amounts of grip on the front. So maybe some camber bolts could help make the setup easier. They are cheap on ebay about £20 Quote
