still its the same shitty size on the collector !! whats the point in having wider runners if they get squashed just the same like the stock 1 ??? no benefit to be had your just paying for a stupid name JAM
a prted stock vs 1 of those will be same in performance
Since when did people's attitude change from wanting proper JDM parts to saying they're shit and no better than a standard ported mani and not worth anything?
The collector size is fine, the turbos that will be used on these manifolds (CT9's and hybrids) are small anyway, the difference on these manifolds is the runners, it's clear just by looking at that picture above that a standard ported mani wont ever flow as well as a JAM one.
IMO people are only slagging this off so they can justify spending money on a shiny stainless steel one. This mani also lets you keep the OEM look which some people want.
Ste91 makes sense all anybody has to know is how wrong can Jam be? They were thrashing lambo's around the Tsukuba 10 years ago with reliable power the problem is the parts are old and well used so most of the parts have been overtaken by newer rivals I would only buy one if it was new which is never going to happen.
It makes sense to buy the wepr kit simply for the lifetime warranty and better power gains and for the little extra as above their price's are just too good for what you get for the asking price of the jdm parts because some people just want silly cash sometimes :(
It may not be worth £300 anymore as there are alternatives out there now, but there's no reason to slag it off, it still stands as a good manifold that is highly unlikely to crack and it retains the OEM look.
Yes you can buy a WEPR one for a bit more but reverse the situation, lets say the JAM mani is worth £200-250 for example, compare it to those cheap shitty low grade stainless manifolds that people buy, I've seen them for around £100-150, so just say someone buys one of them, it cracks (which it is guaranteed to do), you then have to either repair or replace it which means you spend more money and time, so you may as well have just spent extra in the first place and bought a good manifold like this JAM one.
Just because it's not all shiny and new does not mean it's worthless and shit.
Now now 'colin' calm down :)
All the exhaust gases have to go through a ct9 flange so the neck is there whatever mani you run.
granted a wepr or zisco might flow slightly faster but it wont make much odds.
(PS go custom manifold/external gate/bigger turbo = problem solved Lol)
couldnt have said it better.
Phil
Edited by Phil
