Jim* Posted October 5, 2014 Posted October 5, 2014 Fitted some st202 brakes to my glanza, when I changed one of the calipers over I left the brake line unhooked for about 15 minutes obviously taking in air and loosing brake fluid. I've now bled all four corners multiple times and keep getting air coming out, does anybody have any idea what is going on?Have honestly bled them around 10-15 times now and it's just stupid.The pedal has about 40mm travel before it actually catches and starts braking! Quote
morgey Posted October 5, 2014 Posted October 5, 2014 Youve been keeping the bottle topped up enough. It cant go below about 1/2 or it sucks in air. The other easily overlooked thing is mounting the calipers upside down? (Bleed nipple should be ontop) Quote
glanzadude Posted October 5, 2014 Posted October 5, 2014 (edited) What that is wrong I say you put the calipers on the wrong way drives side on the passanger side and act. I did the same with the Glanza with the levin kit.Swap them around and bleed again and I am sure they will be fine Edited October 5, 2014 by glanzadude Quote
Jim* Posted October 5, 2014 Author Posted October 5, 2014 What that is wrong I say you put the calipers on the wrong way drives side on the passanger side and act. I did the same with the Glanza with the levin kit.Swap them around and bleed again and I am sure they will be fineCouldn't be the wrong way because they say RH and LH? And the bleed nipples are on top Quote
Jim* Posted October 5, 2014 Author Posted October 5, 2014 Theres not fluid leaking else where?Have checked and no fluid leaking anywhere Quote
daniel_g Posted October 5, 2014 Posted October 5, 2014 Build as much pressure up as you can and hold the pedal down whilst someone else releases the bleed nipple, pump the pedal a few times, lock the nipple and repeat a few times. Do this all round a good few times constantly topping up the reservoir. Quote
Jim* Posted October 5, 2014 Author Posted October 5, 2014 Build as much pressure up as you can and hold the pedal down whilst someone else releases the bleed nipple, pump the pedal a few times, lock the nipple and repeat a few times. Do this all round a good few times constantly topping up the reservoir.Doing this as we speak Quote
Jim* Posted October 5, 2014 Author Posted October 5, 2014 Build as much pressure up as you can and hold the pedal down whilst someone else releases the bleed nipple, pump the pedal a few times, lock the nipple and repeat a few times. Do this all round a good few times constantly topping up the reservoir.No luck with that either Quote
daniel_g Posted October 5, 2014 Posted October 5, 2014 Only other things i can think of are, force the pedal down and jam a pry bar between it and the seat, then leave it overnight, this normally forces any air to the calipers. Other thing being try get a shot of a pressure bleeder. Quote
Jim* Posted October 5, 2014 Author Posted October 5, 2014 There's without a doubt no air in the system now, bled each corner minimum 12 times and no air came out at the end now but pedal is now still spongey as fuck and dosen't engage brakes until 40mm down Quote
glanzadude Posted October 5, 2014 Posted October 5, 2014 calipers are on the wrong side just swap them around and see Quote
Starlet__SR Posted October 5, 2014 Posted October 5, 2014 Is the master cylinder capable of powering the calipers alright? Have you damaged the master cylinder at all?Day Quote
glanzadude Posted October 5, 2014 Posted October 5, 2014 The master cylinder would be fine shouldn't be that Quote
Jim* Posted October 5, 2014 Author Posted October 5, 2014 How can they be on the wrong side? Surely if I swap sides then the bleed nipples will be on the bottom Quote
maddox710 Posted October 6, 2014 Posted October 6, 2014 Mine did exactly the same Jim, you've just gotta fill up 2 pistons so it takes a lot more juice Quote
glanzadude Posted October 6, 2014 Posted October 6, 2014 What's making me think that is as said before my levin caliper said on it LH but was for the RH Quote
Jim* Posted October 6, 2014 Author Posted October 6, 2014 But then the bleed nipples would be on the bottom wouldn't they if I swap them around? Quote
nick260890 Posted October 8, 2014 Posted October 8, 2014 Try back bleeding it, get one of them squirty oil cans, fill it with brake fluid, put a bit of hose on the end of the nozzle and attatch the other end to the bleed nipple, crack the nipple off and pump the trigger on the oil can, whilst you pumping the trigger get someone to watch the the resivior closly and see if the level rises and see if any air bubbles are rising up through the fluid, but before doing this make sure u havent filled the resivor to the top or ull make a mess, once the air bubbles have stopped coming uo through the resivior tightten the bleed nipples back up, see if the pedal is better and if so bleed it normally (like u had been doing)Hope this helps Quote
