Big end and main bearing sizes
I rang up toyota today to get my bearing set, he checked for me and said the are 3 different types as in 1,2 and 3 I need a standard set for my gt turbo does anyone understand any of this I looked at the clearences from link below its a case of do I order shell set 1,2 or 3 from toyota
http://www.toyotagtturbo.com/forums/showthread.php?27569-4EFTE-Torque-Specs
Thankyou Pat
  • Replies 83
Thankyou Pat
If your asking what i think you are asking then.. you need to get a micrometer or engineer to take a look at your crank and tell you what size you need.
Phil
Thankyou Phil all I know is my crank is standard size no regrind etc it's had a polish etc before engines going back in but Jesus Christ this is getting hard work now trying to find out what sizes I need the bloke at toyota hasn't a clue
The crank for ends and main are 43 (I will double check when next down the unit) so that's means looking at the link chart I will need std mk 1 shells?
Edited by patman
then you have to measure the block to !!! fit the cap ( crank caps ) back on and tighten and check how big the hole is only then you can find out wish size you need best to let the engineer do it
the conrod bearing caps have it stamped on them 4e and 5e
if it was a 5e then its easy for the crank bearings there stamped on block and crank hey hey happy days :) :)
Hello mate so basically I am putting one crank cap on? Or all 5 and tighten them to the torque setting spec, and that will give me what shell I will need (and for rod shells too) obviously with using the correct measurement tools? A micrometer or feeler gauge?
Edited by patman
al main caps need to go back on there nrd 1 to 5 in order then you measure the holes 1 by 1 and write it down you need special tool for that !!!!
( why i say the above ??? is becouse there not al the same size and crank journals arnt al the same size neither
then measure the crank journals if you measure them correctly you can check the spec sheet for the bearing size and see if your still in spec
there ya go
4E-FTE Engine Service Specifications.
Cylinder Head:
Warpage limit (block side) 0.05mm
Warpage limit (Manifold side) 0.05mm
Intake manifold:
Warpage limit 0.1mm
Exhaust manifold:
Warpage limit 0.2mm
Cylinder block:
Surface warpage limit 0.05mm
Bore diameters:
STD mark 1 = 74.000-74.010mm
STD mark 2 = 74.010mm-74.020mm
STD mark 3 = 74.020mm-74.030mm
Limit before rebore = 74.23mm
Piston diameter:
STD mark 1 = 73.900-73.910mm
STD mark 2 = 73.910mm-73.020mm
STD mark 3 = 73.920mm-73.930mm
Piston to oil clearance:
STD = 0.09-0.11mm
Limit = 0.13mm
Piston ring groove clearance:
Top ring = 0.04-0.08mm
2nd ring = 0.03-0.07mm
Piston ring end gap:
Top ring (STD) = 0.26-0.36mm
Top ring (Limit) = 0.95mm
2nd ring (STD) = 0.15-0.30mm
2nd ring (Limit) = 0.90mm
Oil control ring (STD) = 0.13-0.38mm
Oil control ring (Limit) = 0.98mm
Con-rods:
Thrust clearance (STD) = 0.15-0.35mm
Thrust clearance (Limit) = 0.45mm
Big-end inner diameter:
STD mark 1 = 43.000-43.007mm
STD mark 2 = 43.007-43.014mm
STD mark 3 = 43.014-43.021mm
U/S 0.25 = 43.000-43.021mm
Rod bearing centre wall thickness:
STD mark 1 = 1.487-1.491mm
STD mark 2 = 1.491-1.495mm
STD mark 3 = 1.495-1.499mm
U/S 0.25 = 1.607-1.613mm
Con-rod oil clearance:
STD = 0.016-0.048mm
Limit = 0.08mm
Maximum allowable bend in rod per 100mm = 0.03mm
Maximum allowable twist in rod per 100mm = 0.05mm
Crankshaft thrust clearance:
STD = 0.02-0.20mm
Limit = 0.30mm
Main journal oil clearance:
STD = 0.016-0.049mm
U/S 0.25 = 0.017-0.061mm
Limit = 0.08mm
Main journal diameter:
STD mark 0 = 46.995-47.000mm
STD mark 1 = 46.990-46.995mm
STD mark 2 = 46.985-46.990mm
Main bearing centre wall thickness:
STD mark 1 = 1.995-1.999mm
STD mark 2 = 1.999-2.003mm
STD mark 3 = 2.003-2.007mm
STD mark 4 = 2.007-2.011mm
STD mark 5 = 2.011-2.015mm
U/S 0.25 = 2.115-2.123mm
Crank pin diameter:
STD = 39.985-40.000mm
U/S 0.25 = 39.745-39.755mm
Limit = 0.06mm
Circle runout (Limit) = 0.06mm
Main journal taper and out-of-round (Limit) = 0.02mm
Crank pin taper and out-of-round (Limit) = 0.02mm
Torque settings:
Cylinder head bolt:
First 36ftlb
Second - turn 90 degrees in same sequence
Cylinder head to camshaft bearing cap:
9ftlb
Cylinder head to intake manifold:
14ftlb
Cylinder head to exhaust manifold:
35ftlb
Cylinder head to water outlet housing:
13ftlb
Cylinder head to Cylinder head cover:
61inlb ** note inch pounds, not foot pounds! **
Camshaft to Camshaft timing pulley:
37ftlb
Cylinder block to crankshaft bearing cap:
42ftlb
Cylinder block to rear main oil seal retainer:
65inlb ** again note inch pounds **
Cylinder block to oil filter union:
18ftlb
Crankshaft to flywheel:
65ftlb
Con-rod cap to con-rod:
29ftlb (18ftlb then +90 degrees)
Oil pump pulley to drive rotor:
27ftlb
there ya go
Cylinder Head:
Intake manifold:
Warpage limit 0.1mm
Exhaust manifold:
Warpage limit 0.2mm
Cylinder block:
Bore diameters:
Piston diameter:
STD = 0.09-0.11mm
Limit = 0.13mm
Con-rods:
STD = 0.016-0.048mm
Limit = 0.08mm
STD = 0.02-0.20mm
Limit = 0.30mm
STD = 0.016-0.049mm
Limit = 0.08mm
Crank pin diameter:
Limit = 0.06mm
Torque settings:
Cylinder head bolt:
First 36ftlb
9ftlb
14ftlb
35ftlb
13ftlb
37ftlb
42ftlb
18ftlb
65ftlb
27ftlb
this needs to be pinned or wiki'd most useful piece of information ive seen on ukso for long time,
hats off to you colin im impressed :)
Thats straight from toyotagtturbo lol
Phil
Phil
Hello Phil he did give me a bit of paper and on it, it said mains 43 ends 43 if this means anythings that's after it had a polish as didn't need a regrind as got another crank, as my original one was a mess 👍
Colin mate I'm beginning to think your a toyota starlet guru your always on to most things I have noticed, and your an absolute star for helping me out and others out, I don't know what other people do when putting an engine back together esoecially when it comes to the clearances etc etc it's just thrown me when toyota and as stated
in the link what standard mk bearings I need 1, 2 or 3 and I certainly don't wanna pick and hope for the best needs to be spot on,
So what I will do is put the caps back on 1 to 5 and torque them up to what the spec says then get a micrometer and measure the hole inside write them down ( will put the results in here) is this correct please?
Then I will put the ROD caps back on and torque them to the right spec and measure the gap in them, write them down and post them in here is that correct please?
With all the help your giving me mate dam right it's gonna be measured right, this is what messed the rebuild up first time round I can't afford to have it done again, will have I wait till Monday now to do it well I won't be my mechanic will 👍
Hello lads just been doing the measuring for these bearings:
crankshaft mains are 47.00mm std
Big ends crankshaft (rods) are 40.00mm std
Main bearings diameter on all 5 is 45.9mm (almost 46.00mm)
Rod ends diameter on all 4 are 43.00mm
Please could someone tell me which size bearings I need please mk 1, 2 or 3 for big end and mains I would so appericate this in a big way
Thanks Pat
Edited by patman
i need tighter measurements then that you only have thents and hundrerds !!!! we need the measurements in thousands patman like 45.995
you need a finer gauge to measure
you see where you say ere """"" Main bearings diameter on all 5 is 45.9mm (almost 46.00mm)!!!! in that 45.9 to 46 is a tent and 5 different or more sizes bearing will fit in that thent !!!
Thankyou Colin mate now I need to know what exact gauge I need to do this if anyone has any ideas
The bloke from the engineering shop gave me:
Mains on crankshaft 47.00mm
Big ends on crankshaft 40.00mm
Rod bore 43.00mm
Maybe he has just rounded off to the nearest hundreds as you said not thousands? So it's a case now of what gauge I need to get 👍
Rod bore 43.00mm
really an engineer told you them measurements jeeeeeeeez thats no good patman
there never all the same size anyways , thats why we have difernt sizes to go in has the engineer rebuild a engine before ?????? because he should not of given them short measurements attal
