hello again obviously went ahead and brought this gauge to measure the crank diameter etc on my engine rebuild........
http://www.ebay.co.uk/itm/Linear-electronic-digital-outside-micrometer-25-50-/321539792529?pt=UK_Measuring_Tools_Levels&hash=item4add43de91
now its a case of how to set it, I presume you set it with the little 25mm block you get with it, so it would be closing the gap as much as possible, then putting the little 25mm block you get with it once the block is in and holding you set the gauge to 25mm then take the 25mm block out and take it from there when measuring the crankshaft journals? Thanks Pat
  • Replies 83
  • Created
  • Last Reply
Top Posters In This Topic
it will tel you how to exactly in your book you got with it make sure when calibrating her that the contact points are clear of any oills etc etc and yes you use the 25mm extension to calibrate and lock her till the next calibrate
take really good care of the calibrate pin dont ever drop it and dont scratch it
Edited by 5e colin
I do mate I have the 0.25 acl bearings from the other crank and still have the standard bearings from the crank I'm using but them ones are not oem ones, I was gonna use the telescopic gauges to measure inside the rod bores then put that in the micrometer and use the micro meter on all crank journals but there is a 25mm gap on that micrometer hence why I wasn't sure if you set it on the micrometer gauge 25mm, then wind it back to the measurements I need mate
yep thats the way to do it i just mentioned it to try on the bearings so you get the hang of it with the clicks at the end and if the measurements are the same every time etc etc
set the tumbler to zero open the locking valve then measure the 25mm unit relock her and make sure if the tumbler is still on zero then you should be good to go
just read the book of it might be small bit diferent on your 1 ???
Edited by 5e colin
Hello gang this is interesting on the measurements
I now KNOW I need std mk 1 for the main bearings.
On the big end bearings (rods)
I'm getting different sizes to the chart above as it says 43. Something where mine are
From cambelt size
Big end 1 39.989mm
Big end 2 39.985mm
Big end 3 39.986mm
Big end 4 39.987mm
So of course there all very near each other but there not in the 43's as it says in the chart above with the big end diameter.
I'm guessing you have to measure the inside of the rod bore to get the 43. What you need?
Thanks guys (what a pain in the ass)
Pat
Edited by patman
measure the holes like i said before from block mains and the conrod then the crank journals aaal off them mains and big write them down on paper so i can have a look at them on ere
also there is no way them mains are all nr 1 remeasure them
From cambelt size crank
Big end 1 39.989mm crank journal ( outer )..... / cap hole ( inner ) 42.990 to 43.050 ???? somewhere
Big end 2 39.985mm crank journal ( outer )..... / cap hole ( inner )
Big end 3 39.986mm crank journal ( outer )..... / cap hole ( inner )
Big end 4 39.987mm crank journal ( outer )..... / cap hole ( inner )
then you do the exact same for mains inner and outer size !!!!!!!!
Edited by 5e colin
I just wander in to my local engine shop ODCARS at lunch and have big billy check these things out.
I wouldn't know what end of a micrometer to hold lol
Or if they even have ends lol
Phil
My local engineer shop Phil decided to round it all off in hundreds not thousands so he was rounding off the mains to 47mm and the big ends to 40mm
Hence why I am in this postion now as he oh had the gauges what deal in hundreds not thousands
Sorry for the late reply Colin in the end gave it to a very good mechanic friend who's dealt with this stuff before, he texted me at the end of the day quickly to say all the rod holes measured up were all inbetween 43.000mm-43.007mm as gave him the 3 std bearing options for big ends 👍
Edited by patman
Will do Colin mate thankyou soooooo much for all the info and input you have given me I'm thinking a lot of other people could benefit from you and this thread too 👍
I am having this problem too my big end bearings measure to 40mm. But everyone says standard size is 43mm. Does this mean my crank has been reground before ?
Karl
^^^^^ no mate your getting it wrong !!!!!! the crank lobes/journals FOR the conrods is around 40mm BUT the conrods themselves are around 43mm this equals to 3mm and 1.5mm for each bearing cup/half
but you have to measure this in thousands
have a read tru the whole thread so u will see wa tools u need
So patman you just had your bearings done in a nut shell would you just advise to take to someone who has the right mesure tools and get them to do it?
I am hoping I can do them with head still on. Been told to remove sump and crank get it reground and polished and same guy can make up the bearings to suit.
That sound right?
^^^^^ highly unlikely the head can stay on , the rod usually gets damaged and neads to come out top end !!!!!! unles your lucky and got to it intime
but still neads engine out of car and gearbox off if you want to take out the crank !!!!
Colin has nailed it mate it is a pain in the ass I know stripping things down, I would like Colin said check everything and take head off, I got another issue at the moment on the main caps they are numbered obviously 1-5 I know the arrow points to the cambelt side but I can't remember if number 1 starts at the cambelt side or the fly wheel/gearbox side? What a pain
